Good techs to build a weber amp kit
Started by Transcend, December 07, 2010, 09:26:10 PM
Transcend
Ive been looking a lot at the Weber Heather (slo clone) kit and really don't think i'm up to the actual build.
Can anyone recommend a good amp tech/builder in west yorkshire?
I'm going to ask my mate James if he can take a crack at it but i know he hates working with PCB's so don't think he would be interested.
Thanks
i think the heather uses eyelet or turrets.
the layout doesn't suggest PCB at all.
Transcend
Quote from: Dmoney on December 07, 2010, 09:32:41 PM
Ahh that should make my options easier. I read on the sloclone forum that its all pcb
actually
just read back and the thread i was looking at he used the heather chasis and got the rest from elsewhere
the heather isn't quite the same as the sloclone schematic i don't think.
there is a sloclone turret layout for the main and power pcb's. that will fit in the heather chassis.
Transcend
Ah cheers do you have any links? I will have a chat with James and show him the various options and see what he thinks is the best route to take as i know he'll want to be tweaking things along the way and switching components.
There should be a layout page on the forum with it in. I know the forum changed so it may be all over the place now.
I'll take a look later.
There are a lot of potential tweaks. Lots of component changes are straight forward. like slope resistor values and such. down to changing the loop level or if you want a loop at all. just examples. the forum is stuffed with ideas about what you can do. granted its a lot of info to sit and go through.
Transcend
Quote from: Dmoney on December 08, 2010, 08:28:06 AM
Ah thanks a lot im sure i'll be able to find it all.
Thanks for your help
