Could somebody help me out with a HSS config with a split switch?
Started by The Norwegian Guy, December 09, 2010, 06:40:22 PM
The Norwegian Guy
This is what I'm thinking.
MM
MM
Crawler
Master volume
Master tone
5-way switch (normal strat positions 1.neck - 2.neck&middle - 3.middle etc.)
on-on DPDT switch to split the crawler.
I have no idea of what caps to use, or how to wire this thing.
I would appreciate help!
AndreasM
Warmoth
Gibson
EBMM
Eventide
Diezel
Bogner
Pete Cornish
T-Rex
BKP
1reeper
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=HSS_1v_1t_5w
Not sure how good you are with electronics, but this diagram will work for standard strat HSS, for the split, wire the two wires that are usually taped together (not sure of the colour, I only use two conductor) to the center lug, and wire a connection to ground to one side, that's it, you could use a spdt for this if you like.
|O|X|- to ground
|O|X|- two taped wires
|O|O|
I'm not good enough, technically, to be a classic musician. I lack discipline.
ಠ_ಠ
