Need some help with a HSS diagram.
Started by The Norwegian Guy, December 15, 2010, 04:17:51 AM
The Norwegian Guy
1 master volume
1 master tone
5 way switch
- 1 neck (singlecoil)
- 2 neck (singlecoil) +middle (singlecoil)
- 3 middle (singlecoil)
- 4 middle (singlecoil) + bridge (humbucker)
- 5 bridge (humbucker)
dpdt switch to split the humbucker.
Could someone please draw me a wiring diagram? I havent been able to find any, and I've tried search engines.
thanks
Andreas M
Warmoth
Gibson
EBMM
Eventide
Diezel
Bogner
Pete Cornish
T-Rex
BKP
Frank
#1
Deymour Suncan's got this pretty much covered
http://www.seymourduncan.com/support/wiring-diagrams/
edit: http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=1h_2s_1v_1t_5w_pp
... looks like what you need, shows a push/pull pot on the volume knob so just apply that to the DPDT switch
Frank
#2
also, bookmark this link! it'll save you a lot of grief when installing replacement pickups
http://www.seymourduncan.com/support/schematics/schematics.php?schematic=color_codes
edit: although be aware that it may also cause you even more grief as some manufacturers (naming no names, Fender) don't always stick to those colours
Andrew W
The only thing with the Seymour Duncan diagram, unless I'm reading it wrong, and all the others I found is that forces you to compromise on the ratings of the pots and caps you use.  My current build is HSS too and in the end I just changed my design so I can use 500K pots for the humbucker and 250K ones for the single coils (4 knobs a la Les Paul).  All the combined schematics I've seen either use a compromise pot value (say 300K) or just use 250K throughout which doesn't seem like the best plan tonally to me.  If anyone has a killer schematic that solves this I'd be all ears though.
Frank
Changes highlighted in red
guitarmv
Oh my gosh, Frank, that is funny AND helpful. You must be proud.... :roll:
Anyway, I found this thread because I have the same question, got some Bare Knuckles HSS (Geoff/MM) to wire in, and was wondering about this:
Since I don't even usually bother with a tone pot, why not use one of the pot locations for the HB at 500k, and the other for 250k for the two SC's (with one tone pot for all)?
I am going to continue my search for this type of solution, will hopefully find a pertinent answer here...
JacksonRR
Are you looking for one master volume because of the holes you already have in place? Use a dual concentric and a 5 way Super switch. 250 for your singles and a 500 for your humbucker. http://www.guitarelectronics.com/product/CPCS25/CTS-Stacked-Dual-Concentric-Audio-Guitar-Pot-250K500K.html
and
http://www.allparts.com/Fender-5-Way-Super-Switch-p/099-2251-000.htm?click=19167
And wired to the switch terminals as follows:
1 - neck p/u
2 - neck p/u
3 - mid p/u
4 - bridge p/u
5 -
0 - 250k volume pot
1 -
2 - mid p/u
3 -
4 - mid p/u
5 -
0 - 250k volume pot
1 -
2 -
3 -
4 -
5 - bridge p/u
0 - 500k volume pot
1 - from 250k pot
2 - from 250k pot
3 - from 250k pot
4 - from 250k pot
5 - from 500k pot
0 - to master tone and output jack
JacksonRR
And a 250K push pull pot for the tone/hum splitter. Sorry forgot.
