Author Topic: Also in need of HSS wiring help!  (Read 3975 times)
Hansi
« on: December 21, 2010, 07:20:38 PM »
:oops:
Well the other threads below weren't exactly what I was looking for right now so I thought I'd ask in case someone could give me a help as I'm tired after a long day at work and just want to get my brand new set of Holy Diver & 2 Trilogy Suites installed quick...  :|
What I'm trying to do is to wire the pickups exactly like this: http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=1h_2s_1v_1t_5w_as.
So that the pickups would work like following on the different switch positions:
Pos. 1 - Neck
Pos. 2 - Neck & Middle (hum-cancelling)
Pos. 3 - Middle
Pos. 4 - Middle & HB slug coil (hum-cancelling)
Pos. 5 - Humbucker
Now what color goes where in that diagram with the BKPs, I'm assuming they're not the same as on Duncans? Should I put the RWRP single-coil in the middle or in the neck to get the combinations mentioned above?
Thanks in advance!  :D
Hansi
Re: Also in need of HSS wiring help!
« Reply #1 on: December 22, 2010, 07:03:56 AM »
Well I guess I figured out the colors, that shouldn't have been so hard since black is ground and red is hot on BKPs... :oops:
What I still need to know is whether to put the RWRP single in the middle or the neck. The pickups came with the RWRP one marked as "neck" but I'm not sure if that's how it's meant to be if I don't split the bridge humbucker in which case pos. 4 on the switch is going to be hum-cancelling anyways...  :?:
