Bridge & Neck Strat Pickups
Started by MrBump, December 22, 2010, 07:07:27 AM
Chaps, is there an easy way of wiring a switch into a normal 5 way strat switching system to allow neck and bridge in parallel?
Can it be done with a toggle switch, or push/pull pot?
Mark.
Either the Schaller Megaswitch or the Superswitch will let you do it.  The megaswitch is available from Stewart MacDonald's in the USA.  Bare Knuckle, StewMac and Allparts stock the superswitch.
Quote from: PhilKing on December 22, 2010, 09:01:59 AM
Cheers - I've used them in the past and they've been great.
However, I was thinking more along the lines of keeping the stock switching and ADDING an additional switch...
Mark.
