Author Topic: Pedal noise - help!  (Read 2275 times)
mikeluke
Pedal noise - help!
« on: December 23, 2010, 02:58:16 PM »
My Marshall Guv'nor has just developed a whine - sounds like bad interference - worse on power adapter than battery - swapped for another OD pedal and that works fine - does anyone out there fix pedals? It is my favourite and I don't want to junk it!
Thanks
Mike
Mules, Riff-Raff
juansolo
    • Juansolo's Gnomepage
Re: Pedal noise - help!
« Reply #1 on: December 23, 2010, 06:26:23 PM »
Can have a poke around at it if you wish (though will have to be after the holidays).
Modular1
« Reply #2 on: December 27, 2010, 01:42:35 AM »
Give it a whack.
« Reply #3 on: December 27, 2010, 11:31:03 AM »
Most likely a grounding issue or a loose solder joint.
Pete24v
« Reply #4 on: December 27, 2010, 01:45:18 PM »
my mk1 Guvnor did this, turned out to be a dodgy battery clip.
mikeluke
« Reply #5 on: January 04, 2011, 09:24:31 AM »
Juan - thanks for the reply - been away over Xmas - I will get one of the guitarists in the band to double check and then IM you
Regards
Mike
Mules, Riff-Raff
juansolo
« Reply #6 on: January 05, 2011, 05:07:54 PM »
No worries.
mikeluke
« Reply #7 on: January 06, 2011, 09:19:49 AM »
Well... looks like it must be a dodgy lead or something - was not whining with my mate's set up - although the pots do need a bit of switch cleaner on them (I tend to leave it on the same settings) - so, back to the drawing board to try to understand what is causing the interference. Will move everything to another room and swap the leads one by one to see if I can track it down.
Regards
Mike
Mules, Riff-Raff
