Author Topic: NAD: It's here! AFD100 in the house!  (Read 143045 times)
Re: NAD: It's here! AFD100 in the house!
« Reply #210 on: March 09, 2011, 12:55:29 PM »
is this review online anywhere?
Brow
« Reply #211 on: March 09, 2011, 12:58:34 PM »
They tend to put them online themselves (the mag) a month or 2 after the issue has been on sale.
jpfamps
    • http://www.jpfamps.com
« Reply #212 on: March 09, 2011, 04:54:16 PM »
Yep, I was surprised with the 'less than glowing' review GnB gave the AFD100 too.
I've been getting that magazine pretty much constantly for the last 12 years or so and don't remember reading an amp review quite as scathing as that 1 came across as being  :?
I heard from some who works as a music journalist that it had got a bit of a clattering in the review (I haven't seen the review myself).
Perhaps the reviewers are getting bored with giving everything a glowing review and there will be a bit of a backlash.
Hope not as one of our amps is going for review soon.......
ToneMonkey
« Reply #213 on: March 09, 2011, 04:55:26 PM »
So what's the score now Dave?  Any more issues?
« Reply #214 on: March 09, 2011, 05:13:59 PM »
It's wobbled once in 3 weeks, and only once.  That was at the minimum power setting late one night.  Otherwise it's been fine  :?
metale
« Reply #215 on: June 14, 2011, 08:48:23 PM »
Did you guys see that other thread on another forum where the amp designer came in and in the end everybody agreed that the problem was normal behaviour at lower power reduction settings, caused by voltage flutuations, and solved by the use of a voltage regulator on those places?
« Reply #216 on: June 14, 2011, 11:17:41 PM »
Yup.
trinaamp
« Reply #217 on: December 12, 2013, 11:08:26 PM »
Nope - no schematic Fernando.
I've subscribed to the Marshall forum so there's now at least three of us there with an issue.  Not good for Marshall is it?
Indeed not good.
From what gwEm says, sounds like it is a well-known problem with this sort technology, which would suggest that Marshall don't understand it fully.
I've logged into the "super secret" Marshall schematic service facility and there's no schematic there. I expect there won't be until it goes out of warranty.
Regarding the "Power Scaling", what I have gleaned is that the screen grid voltage and bias voltages are varied, rather than the plate, screen and bias voltages, and that this is controlled by some digital which has a number of stepped power levels, and this seems to be where the problem is.
As ever, using "cutting edge" approaches often reveals unexpected problems.
Hello.
The thing is the following:
1)First of all AFD and YJM use the same EPA (electronic power attenuation) circuit: I have made comparison by looking PCB and also by reading in the manual the explanations on autobias, on the use of the POWER pot in AFD (called LEVEL in YJM) I am quite sure is exactly the same circuit.
2)It is all based on a patent of the 80's that expired few years ago (therefpre Marshall use it without infringment). This patent was based on moving bias (control grid) and screen grid voltages in order to keep their ratio constant. If you do that the characteristic of the tube keeps the same shape (tone remains the same) but the clipping point moves to lower levels.
3)According to Marshall designer Santiago Alvarez they made some difference respect to the patent. By examining the AFD circuit (missing the digital part schematic) there are 4 regulators which provide a negative voltage for the bias and one High Voltage regulator, which provides screen voltage.The bias ones are following a voltage called VBC1 while the screen voltage regulator follow a voltage called VS. I don't have the schematic of the digital part of this amp (nobody has posted it yet) but I am quite sure that VBC1-4 and VS come from a digital control (like a microprocessor that digitally drives the voltages trough DACs) according to POWER potentiometer position. Moreover the LEVEL/POWER control acts at our ears like a "step" volume and not linear. This may confirm that there is a digital circuit controlling bias and screen voltage according to certain equations/laws or a simple LUT (look up table). Instead the original patent of the 80s was keeping screen voltage/bias ratio approximately constant with a continuous range (full analog!).
4)Finally remember that current in Pentodes (power tubes) do not depend on plate voltage but strongly on screen voltage (and of course also on control grid).
5)The POWER potentiometer is double (shared axes): one acts probably on the (missing schematic) digital circuit that, on his turn, regulates VS and VBC1-4; the other one acts on the power stage feedback in a way that it tries to compensate (as Alvarez stated) the power stage when changing POWER level. This should be done because when you change bias/screen voltages the stability characteristic of the circuit change, therefore you have to adjust the feedback to try to keep them constant.
4)Conclusions: this is the best post phase inverter volume reduction because it does not use any kind of potentiometer/circuits in the analog path; it reduces the power maintainig the characteristics of the power tube constant. It is the ultimate mod for any NON master volume amp. What is difficult to achieve is to implement the bias/screen regulating law using an analog circuit instead of microprocessor (if it uses micro according to my supposing...again, missing the digital part schematic that would reveal if my supposing is true).
The EPA circuit works also on EL34...the manual of YJM and AFD tells that trough a bias table!
Hope I gave an help with this.
Regards
« Reply #218 on: December 13, 2013, 01:27:38 AM »
First of all, way to dig up a thread from 2011.
I'm sure the AFD and YJM have the same or if not the same a very similar circuit to do the power attenuation, whatever they call it.
Attenuating the screen grid variable voltage is more easily done than varying the plate since the power needed to be dissipated is lower. I don't think it is difficult to get a variable screen voltage with bias tracking without the aid of a microprocessor and without having high voltages on any pots, it may be a bit less accurate in terms of how it tracks bias but this idea isn't new at all. I think this circuit also works using 21 steps and appears to have had some dither issues. Essentially this is using a dual pot controlling a digital circuit in turn controlling variable bias and variable screens and in an analog fashion varying the negative feedback, which is the long and short of what JPF said.
I'd say it's probably one of the better concepts for a circuit of it's kind, but how it has been implemented may have left a bit to be desired. Also, if you're Non Master volume head doesn't use negative feedback, you wouldn't have to 'mod' it to use a circuit that varies the negative feedback along with output power, correct? So you may not want to use this circuit in 'ANY' non master volume head.
I'm also a fan of keeping it simple and reliable, especially when it comes to the bias circuit. Using common parts and keeping things easily repairable is always a good touch in my opinion. If I broke a microprocessor in a guitar amp and I was on tour, what would I do? meh. That's just my personal thoughts on that stuff.
