Author Topic: x64 IR convolver plugin anyone?  (Read 6068 times)
Keven
« on: January 06, 2011, 01:19:11 AM »
sorry about the onslaught of posts in tech, this is a different issue!
i've recently hit a wall in my use of impulses. our new studio's DAW and computer are based around x64 windows 7 architecture. and i can't seem to find any free or paid for IR plugins that work under x64. i know jbridge might do the trick in allowing me to run kefir or LeCab under x64, but i'd like to avoid bridging. even the presonus support guy didn't know of any IR convolver that ran under x64.
thanks for any info you guys can chime on this!
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
  • Truly bad since 1972
Re: x64 IR convolver plugin anyone?
« Reply #1 on: January 06, 2011, 05:06:20 PM »
studio devil pro uses impulses sure my mate has on his x64 windows 7 system
« Reply #2 on: January 06, 2011, 05:07:10 PM »
and le cab works for me on mine
Transcend
« Reply #3 on: January 06, 2011, 05:47:42 PM »
all 32bit plugins still work in x64
If you are using reaper they do anyway
ive never had a problem
Keven
« Reply #4 on: January 07, 2011, 03:44:22 AM »
i'm working in studio one. and from what i've read, it depends how you run the DAW. i run studio one in x64 and only x64 plugins show up
i've solved my problems anyhow, liquidsonics reverberate is a nice little one that works in x64 and allows me to load impulses and also cycle them one after the other.
thanks anyhow!
My BK's:
Transcend
« Reply #5 on: January 07, 2011, 06:14:57 AM »
Glad you found a solution Keven
