Author Topic: 50s style Microphones.  (Read 5815 times)
PESIMAX
« on: January 07, 2011, 10:11:26 AM »
Hello, the singer in my band want's a 'retro' mic..she mentioned the one dave vainian uses in the damned. I own a couple of shure, but can't really afford to spend the 180 quid it is for their 'elvis' model.
However I have found this reduced from 64 to 30, now I'm not sure about the ins and outs of mics, but for a live situation will this mic do? http://monacor.co.uk/products/prosound-microphonedynamic/vnr/233590/
has anyone tried this mic/company, I know it's not going to be as good as shure but will i get a alright sound from it?
all the best
George
p.s it's snowing :)
« Last Edit: January 07, 2011, 10:46:21 AM by PESIMAX »
Re: 50s style Microphones.
« Reply #1 on: January 07, 2011, 11:21:11 AM »
If the requirement is '50s looking' then your options are pretty limited anyway.
For 30 quid, you may as well. FWIW 180 isnt much for a mic, really, and its likely rubbish, but you havent lost much.
JacksonRR
« Reply #2 on: January 07, 2011, 01:17:29 PM »
PESIMAX
« Reply #3 on: January 07, 2011, 01:21:56 PM »
It seems like all the cheaper mics are all from the same chineese factor, just rebadged.
PESIMAX
« Reply #4 on: January 07, 2011, 01:32:39 PM »
oh yeah and here's the tech specs
Transducer type . . . . . . . . . . . . Dynamic moving coil
Operating principle . . . . . . . . . Pressure gradient
Frequency response . . . . . . . . . 50 - 18,000 Hz
Polar pattern . . . . . . . . . . . . . . Cardioid
Nominal impedance. . . . . . . . . 300 Ohms
Sensitivity. . .......... . . . . . . . . . -77dB ±3dB
Weight w/out cable. . . . . . . . . . 510g
PESIMAX
« Reply #5 on: January 07, 2011, 04:12:35 PM »
I've decided to just go for it, might as well try it. If it's awfully it'll do for a prop or just general jamming/ backing singer mic.
Denim n Leather
« Reply #6 on: January 08, 2011, 04:06:45 AM »
The mic you are probably looking for is a RIBBON mic, not a dynamic one ...
Alex
« Reply #7 on: January 08, 2011, 08:08:27 AM »
The Shure is the way to go.
http://www.thomann.de/de/shure_sh55_serie_ii.htm
With a 144€ it really isn't overpriced. My friend has used his for many years - in a rock/metal band.
It's when you constantly have little problems with a mic onstage/during rehearsal that you'll be glad you spent the money and bought a proper one.
« Reply #8 on: January 08, 2011, 02:51:29 PM »
using a cheap mic in a live setting is asking for trouble - feedback.
do it right first time, you can get the Shure 55SH from Thomann for £119.00
PESIMAX
« Reply #9 on: January 08, 2011, 05:15:18 PM »
i wonder if i could put a sm 57 or 58 cartridge in the cheaper mic? I've got a couple of those mics that i don't use.
nfe
« Reply #10 on: January 09, 2011, 04:48:37 PM »
My guess is that it's the look, not the sound, that they're after.
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
« Reply #11 on: January 12, 2011, 01:35:58 AM »
they used a lot of valves in the 50s, so maybe a valve mic would be the best option, also ribbon all the way, something like this: http://www.thomann.de/gb/the_tbone_rb100.htm
« Reply #12 on: January 12, 2011, 08:34:46 AM »
ribbon for playing live? would it be robust enough? i dunno much about mics
Denim n Leather
« Reply #13 on: January 12, 2011, 12:29:23 PM »
The short answer is yes. Where does the OP say anything about live use?
« Reply #14 on: January 12, 2011, 12:36:36 PM »
He doesn't. i was just asking a question, soz.
besides, after the post about buying a cheap 50's styled mic for the look and then ripping apart an SM5X to stick in it, i assumed it wasn't for studio use. Seems to be more about the look, rather than anything else... in which case, few people would really appreciate the look if it was just for studio use.
