Author Topic: Apaches specs changed?  (Read 4739 times)
5F6-A
« on: January 12, 2011, 06:36:16 AM »
Hello all,
I got a set of aged Apaches personally wound by Tim about 5 years ago. They read 5.8k for neck anc middle and 6.45k for the bridge.
This was a slight underwound from the stock Apache values. Still the new BKP website states that Apaches are wound at 5.6k, 5.6k and 6.4k which is even lower. Have the specs changed? 5.6k is very low for a strat pickup.  is it to accomodate for a change in the wire or otherwise?
Cheers!!
"I now consider atheism to be brutal because it offers neither consolation nor liberty of any kind" Benjamin Constant in 1804
"Practice until you can hear the metronome grooving" Carol Kaye
Tim
  • BKP
Re: Apaches specs changed?
« Reply #1 on: January 13, 2011, 08:24:56 PM »
The bridge is exactly the same but for the past 4 or 5 years I have been winding the mid and necks a little lower at DC5.6K - this is not low at all for a single coil and is particularly well suited to neck and mid slots which benefit from the lower resistance.
Tim
5F6-A
« Reply #2 on: January 14, 2011, 06:24:29 AM »
So new Apaches are a tiny bit less hot than the old ones ( minus the bridge)? Ahh i get it. Thanks so much, Tim.
I love my set BTW.
