Author Topic: Parallel effects loop problem with chorus pedal  (Read 2236 times)
schenr
« on: January 14, 2011, 01:58:45 AM »
Hi all,
As you may have already gathered, I'm having a problem with the parallel effects loop when I engage my chorus pedal.
On the clean channel it works perfectly, no problemos whatsoever, but on the gain channel, the chorus effect doesnt come through at all. I've tinkered with the effects loop level knob, going from bypassing the loop to 100%, and tried 3 other choruses and none of them seem to come through. I know the loop is functioning on the gain channel because my delay pedal does come through.
The amp is a bogner alchemist, and I've attempted to find out about this problem on the net, and the only info I've found out is that it may be an out of phase issue, but that's as far as that discussion went.
Has anyone else run into this same problem and can shed some light? I could always just quit my whining and chuck the chorus infront of the amp...
Thanks
