Warpig question
Started by andrew11, January 18, 2011, 06:03:22 PM
andrew11
Looking into a set of warpigs for my Jackson Soloist alder with maple neck through. Guitar seems naturally bright and trebally. Looking for a pickup to really beefin up the guitar, lots of mids and bass. I play just metal with this guitar so I was thinking the warpig would be good. Now with the warpig you have 2 options ceramic or alnico. My question is with the magnet size: do they use regular sized ceramic and alnico mags or custom? My idea is to order the alnico and try a ceramic if I don't like it. I have reg and oversized ceramic mags for various Duncan pickups but will they fit in the warpig? Thanks
Warpig set (ceramic bridge)
Madsakre
Which kind of metal do you play? What sound are you after(name a band)
Which amp do you play on?
Do you have a clip where you play?
Cattlepress
andrew11
My amp Peavey valveking 212 combo 100 watt. As far as type of metal think Metallica, Black Label Society (main reason for looking at warpig read in total guitar it was designed to replicate zakks sound), Pantera and lamb of god. Looking for a real full sound. I have Duncan Distortions now and there too bright and lack that big full sound. I guess i'm looking for more bass and a darker pickup. Hope that makes sense.
Madsakre
You should take a look at the Miracle Man
Cattlepress
Doadman
Quote from: andrew11 on January 18, 2011, 06:51:15 PM
I remember rerading that and I've never quite been able to see it. I mean, yes, it's true to a degree but I think other pups in the BKP range are more suited to Zakk's tone. Having said that, If you're wanting HUGE bass and mids, an Alnico Warpig is the way to go. I seriously considered one for my Soloist but unless Tim tells me I'm wrong, I'm going in a different direction. I'd agree with Madsakre that you should look at the Miracle Man. Here's a link to a sample of a Miracle Man nailing Zakk's tone. This is Tim playing in his Ozzy tribute band.
http://bareknucklepickups.co.uk/forum/index.php?topic=2941.0
andrew11
I was thinking miracle man but the only thing that scares me is the EQ looks similar to my SD distortion which is really bright in my guitar. The warpig just looks like it would suit a bright trebly guitar but I'm no expert that's why I'm talkin to u guys.
Doadman
I'd agree that you need to avoid bright pickups like Cold Sweats, Rebel Yells etc. but maple neck-thrus are usually described as being very middy, though I imagine the alder in the body brightens it a bit. Because they're middy, the Miracle Man suits them very well indeed. Nevertheless, a Miracle Man is a VERY popular choice for maple neck-thrus. It wasn't for me, simply because I wanted a sweeter alnico tone rather than ceramic but for what you're after the Miracle Man is ideal. I remember Feline Guitars telling me that a Miracle Man was perfect for maple neck-thrus, as did Tim and I think Nolly may have done so too. These are people who really know what they're talking about so it's worth at least considering. The Miracle Man will get you far closer to a Zakk Wylde tone than a Warpig but of course, if you want a much bigger, bassy sound than Zakk then the Warpig is certainly the way to go.
andrew11
I'll take a closer look at the miracle man and listen to some more clips. As far as the warpig how do u think it would sound in my guitar? How would the ceramic warpig compare with the miracle man? Also Anybody have a answer for my magnet question in the orig post?
Doadman
I think the Warpig should sound great in a Soloist if you want that really huge sound. The ceramic option is much tighter and more aggressive to my ears but the Alnico version cleans up better and has a much sweeter lead tone. I found listening to entire clips a bit confusing but if you listen to the first 22 seconds of each Modern Metal clip side by side, that will give you a very good idea of their rhythm qualities. Then listen from 22 seconds to 45 seconds and that will compare their lead abilities. I found the rhythm of the C-Pig to be marginally superior to the A-Pig but the A-Pig was noticeably better on the leads, though in fairness, I'm after an alnico pup so I would say that. You could include the Miracle Man in this comparison too. I found that listening to the clips this way helped to highlight the differences between them.
I'm afraid I have no idea about your magnet question.
dheim
hi!
there's no way a Warpig could ever be meant to replicate an EMG81 tone, i think they're at the opposite sides of the spectrum, tonally speaking...
the WP has got an aggressive, dirty and grindy tone full of mids that's great for many kinds of metal and rock - even if your reference tone makes me think about the Miracle Man. i've got a maple nechthrough and it's really not that middy, so the MM could sound a bit scooped (that could be exactly what you're looking for, given your Metallica and BLS influences...)
i wouldn't suggest you the C-pig, if you think ceramic maybe you think Metallica and such, but it's a whole different beast that gives you instant death metal tone, even on standard E tuning.
too many? ;)
Doadman
If you want an EMG81, Zakk tone then you certainly need to rethink the Warpig because it's just not the right tone for it. The Miracle Man would be a great option and I think the Aftermath may also be a good idea for that super tight style. Having said that, you also say you want to beef up the guitar with lots of bass and mids. That would suggest a much bigger sound than would normally be associated with a tight pickup like an EMG. If that is your priority then the Warpig is a very good choice. I think you just need to listen to the clips on the main website and choose on what you like best from your gut rather than thinking of someone elses tone.
the nailbomb (both versions) might work
maybe better than a miracle man
Quote from: andrew11 on January 18, 2011, 10:09:57 PM
the miracle man sounds nothing like the distortion at all
the distortion is much middier, brighter, less bassy and A LOT more compressed
ratspeak
I have a ceramic warpig in a maple neck-thru guitar. I think you'd be fine with either, but for your style my vote goes to the Alnico Warpig.
visitorQ
Quote from: Eric Hellstyle on January 22, 2011, 07:42:32 PM
Here you can find a guitar like yours (maple neckthru with alder wings) with bareknuckle nailbomb (Alnico). I always looked at this clip for the Nailbomb. Still, this guitar is detuned in B. I don't think it suits your style, but sounds great.
http://www.youtube.com/watch?v=bVDLXQ60_oI
