Author Topic: Neck pickup suggestion for Les Paul  (Read 5881 times)
« on: January 19, 2011, 05:06:21 PM »
Hi,
I have a Les Paul for which I want new pickups. I have tried a few different sets in this guitar but no BKPs yet. Most of the bridge pickups I tried were OK but any PAF type neck pickup was always far too bassy and muddy on the 3 bottom strings no matter how it was set (pickup height, adjustment of polepieces - pots are CTS 500k BTW). The pickup with the least muddiness was a Wilde by Lawrence L-500C but unfortunately the guitar does no longer sound like a Les Paul. There must be a way to get the Les Paul tone without the muddiness on the lower strings or are these intrinsically intertwined?
So I am first looking for a neck pickup that is really tight in the bass and clear/full in the rest of the frequency range, and then match the bridge pickup to it. The tone should be typically Les Paul so I was looking at the vintage and vintage hot categories. This guitar is intended for blues rock and classic rock - no metal.
From the descriptions and tone charts it seems that Riff Raff and VHII would come closest to what I am looking at. I ruled out Mules and Stormy Mondays for now because they may be too bassy in that guitar as well.
Any comments would be greatly appreciated.
Thanks and kind regards,
Stephan
Re: Neck pickup suggestion for Les Paul
« Reply #1 on: January 19, 2011, 05:11:38 PM »
riff raff set, brother
 :D
« Reply #2 on: January 19, 2011, 06:14:13 PM »
VHII is awesome for the neckposition. I'd stick to a Mule for the bridge (closest to the '59 PAF-tone).
Nolly
  • Global Moderator
« Reply #3 on: January 19, 2011, 08:27:36 PM »
I agree with Eric's Riff Raff recommendation, though I don't think the Mules would have any clarity issues whatsoever.
« Reply #4 on: January 19, 2011, 08:45:38 PM »
i also think riff raffs
« Reply #5 on: January 20, 2011, 01:39:33 PM »
Thanks guys, this seems to be an easy one :D.
dheim
  • DON'TPANIC!
« Reply #6 on: January 22, 2011, 01:11:20 PM »
my neck mule has a great, bright and definite sound in my LP... easily one of my favourite neck pickups! ever thought about a Mississippi Queen?
too many? ;)
« Reply #7 on: January 24, 2011, 10:51:59 AM »
I have one Mississippi Queen. To be honest, it was not what I wanted to hear in that particular guitar. While it helped with the muddy bass problem it had too much midrange and not enough highs. Also - being a true single coil - it hums.
« Reply #8 on: January 19, 2012, 09:46:02 AM »
I have not followed this up for a while until very recently when I did a little experimenting with various bridges. I found out that this particular guitar had a very dark sounding bridge. I now fitted a Duesenberg steel saddle bridge which made the guitar quite a bit brighter.
I then stuck the Abraxas neck in the neck position and bingo - muddiness bye-bye. Great fat lead tone for sure.
I have not finally decided on the bridge pickup but I guess that's an easy one - I probably just get the Abraxas bridge.
gordiji
« Reply #9 on: January 19, 2012, 05:00:18 PM »
i can't make a recommendation (positive one) but your right to stay away from stormy II in the neck because it can be boomy and flabby. it's great clean and earns its money higher up the register when driven giving lovely creamy tones,
it's a trade off.mines in an LP and i love it paired with a vhII.
wolfenstein
    • Facebook
« Reply #10 on: January 19, 2012, 09:03:52 PM »
I had the same problem with my Les paul...Dark and mudy..I emailed Tim and he answered Riff raff in bridge...Also I asked about Emerald as higher output option he said  ""the Riff Raff is going to have the tightest bass response - the Emerald will have more output but it will reproduce more bottom end too.""
have CWP,MM...had AM,CS,VHII,NB,PK,HD...
« Reply #11 on: January 20, 2012, 08:26:22 AM »
The bridge pickup was never a problem in that guitar. Every bridge pickup I had in there sounded good or better. But the neck pickup was always a problem, especially on the wound strings.
That particular case just goes to show that pickups are not alone responsible for the total sound but only part of the picture, as is the hardware (as is the amp and the player).
