Miracle Man - custom 5-way wiring...?
Started by ShredHeadJHJ, January 22, 2011, 02:35:03 AM
ShredHeadJHJ
Here is the scheme I really really want:
1) Bridge hum FULL
2) Bridge & Neck OUTER COILS
3) Bridge & Neck INNER COILS
4) Neck INNER COIL
5) Neck hum FULL
Hereeee's my question... Is this even worth doing with the Miracle Man's? It would be an awesome wiring scheme, but I don't even know if it would be worth it, since these pick-ups aren't exactly versatile...
As a side question - How would NailBomb's work in a basswood body / maple topped Suhr Modern?
I have a Miracle Man set using PRS 5 way wiring in a PRS clone with a black korina/maple body and rosewood/ebony neck.  The settings are:
1 Bridge humbucker
2 Inner pickup coils, parallel
3 Outer coils, series
4 Outer coils, parallel
5 Neck humbucker
However for this to work correctly you have to flip the magnet in one of the pickups (best way is to order it like this).  I find that it gives me a lot of tones that I wouldn't expect from the description of the Miracle Man.  I get great blues and classic rock tones from it.
ShredHeadJHJ
Quote from: PhilKing on January 22, 2011, 04:21:11 PM
What's the difference between series and parallel??
JacksonRR
Quote from: ShredHeadJHJ on January 25, 2011, 05:42:36 PM
Series is the normal method of combining pickup coils, parallel gives more mid cut and is like the combined setting on position 2 & 4 on a Strat
James C
Quote from: PhilKing on January 26, 2011, 01:24:54 PM
As above
series = higher DC resistance, Parallel = lower DC resistance.
really want to try a MM set with a 5 way now
Formerly "ManOnTheEdge"
Frank
Hey nonny ding dong, alang alang alang, Boom ba-doh, ba-doo ba-doodle-ay ... http://www.deaf-eddie.net/drawings/dbl-fat-prs.jpg
ShredHeadJHJ
SCHWEET!!! How would flipping the magnet affect the sound when the hums are on full? How do to bridge/neck outer coil's sound differ when they are in series compared to parallel?
Frank
No idea, you should probably ask a PRS owner. I don't play anything that doesn't say Fender on the headstock.
