Author Topic: big block floyd rose upgrade  (Read 2477 times)
braintheory
« on: January 23, 2011, 09:52:45 PM »
I wanna upgrade the block in my Dean CFH with a titanium block.  The problem is the smallest one they make is 32mm, while the block in my Dean in 30mm.  Will the 32mm still fit?
Engl Artist Edtion
Engl Invader
Friedman Phil X
Gower Rockmonster
Mesa/Boogie Mark III Coliseum
Mesa/Boogie Mark IIC+
Peters FSM/Halo
Randall Thrasher
Rhodes Gemini
Wizard Modern Classic
JacksonRR
Re: big block floyd rose upgrade
« Reply #1 on: January 23, 2011, 11:46:03 PM »
Very likely that it will, but it all depends on how much clearance you have between the trem block and the cover when you're bar is pulled back. If you have almost enough clearance for 32mm, but not quite, you may be able to round out the back corner of the new black as that is the part that would be hitting the cover. You probably won't have to do this, but it's an option. Just measure some more things and see.
« Reply #2 on: January 24, 2011, 09:58:22 AM »
Titanium block?
How novel.
Why?
