Author Topic: Any body using Black Dogs in an SG ?  (Read 2113 times)
Ronnie Robinson
« on: January 26, 2011, 07:02:16 PM »
I want to try some BKP pickups in my Gibson SG. Ive already tried the bridge Riff Raff and didnt like it in my SG so they are out and I use a PRS with mules which sounds great but want something different.
Black dogs sound great in a Les Paul so is anyone using them in an SG?
PRS McCarty (BKP Mule set)
Fender USA Strat deluxe (Irish Tours)
Gibson Sg Standard
Re: Any body using Black Dogs in an SG ?
« Reply #1 on: January 26, 2011, 10:25:35 PM »
what exactly you didn't like about the riff raff?
Ronnie Robinson
« Reply #2 on: January 27, 2011, 07:52:30 AM »
It gave a sound I can best describe as 'sterile' which Ive not found in the Mule or Crawler pickups
Gibson Sg Standard
gueorgues
« Reply #3 on: January 27, 2011, 08:01:56 AM »
I would not suggest mid output pickups for a SG. If you don't like the riffraffs and I presume you want to stay PAF on this guitar - I would suggest you try Stormy Mondays or Mules with Alnico II .
Another option is the Mississippi Queen set.
I have a Standard SG with a MQ set in it and it is a total keeper. As much as I like changing pickups and messing around with my guitars - since I've gotten those I haven't touched it.
« Reply #4 on: January 27, 2011, 11:24:13 PM »
Indeed, look at the MQ's and the Nantucked.
Alex
« Reply #5 on: January 28, 2011, 04:40:18 PM »
I have a Black Dog in my SG's bridge and it works amazingly well.
I first had a 498T in there, then a Miracle Man and now the Black Dog and this is clearly my favorite. It doesn't have a lot of output but very complex mids and solid bass/treble. It doesn't scream, it growls very nicely. It often feels like it has enough power, but you do feel the PAF clarity typical of lower output humbuckers. I did replace the pots with new 500K ones to ensure it isn't too dark - the original pots were around 300 I think. This also brightened the neck humbucker up a lot btw.
So if you get one I would order some new pots as well at the same time.
