Author Topic: New set of wiring gubbins  (Read 10984 times)
Nadz1lla
    • Arcanum Plectra
Re: New set of wiring gubbins
« Reply #15 on: March 02, 2011, 10:16:33 PM »
Cheers dude, what about the new caps? Tim rec'd two, one for neck and one for bridge. Any idea where I put them in the chain?
Transcend
« Reply #16 on: March 02, 2011, 10:17:44 PM »
2 caps with just one vol & tone?
i've never come across this before i just generally go with whats on that diagram
you do have a 3 way toggle dont you & not a blade?
Transcend
« Reply #17 on: March 02, 2011, 10:21:53 PM »
If its the blade method i cant find any good diagrams but i can dissasemble my RGA and tell you exactly what pins you need to solder to
Nadz1lla
    • Arcanum Plectra
« Reply #18 on: March 02, 2011, 10:22:02 PM »
Yeah.  o_0
I was sent this:
For use with humbuckers I recommend our new CTS550K custom audio taper pots for both volume and tone applications and our BKP/Jensen paper in oil capacitors - 0.022mfd for the bridge tone and 0.015mfd for the neck tone.The 550K rating loads the pickup less allowing for slightly more output and increased high end response with improved dynamics while the paper in oil caps maintain clarity and definition during treble roll off as well as a more usable tone sweep.
Ah I see now.... I was mistaken, I have 2 vol and a tone. D'oh!  >_<
Oh and defo a toggle, not blade.
Transcend
« Reply #19 on: March 02, 2011, 10:24:54 PM »
ahh in that case you can use the official diagram
http://www.bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/2_hum__2_vol_1tone__3_way_toggle.pdf
you could always convert one of the vol pots into a tone by placing the cap in the same place as it is on that diagram across one of the pots
I however would find 2 vol more useful
As generally i just have 1 vol & the switch other than on my RGD as that has parrallell wiring and the tone pot has a nice effect in that mode
Nadz1lla
    • Arcanum Plectra
« Reply #20 on: March 02, 2011, 10:28:04 PM »
Seeing as I bought two I might as well use them. Plus I like a little variance in tones sometimes, heh.
Transcend
« Reply #21 on: March 02, 2011, 10:29:32 PM »
hmm im not quite sure how you would go about wiring it
check the bkp site for
2x humbucker 1 vol, 2 tone 3 way toggle
because youll have to have the volume as a master volume
