Author Topic: New set of wiring gubbins  (Read 10983 times)
Nadz1lla
    • Arcanum Plectra
« on: February 16, 2011, 07:03:22 PM »
Hey all,
Pretty new to wiring, did my own set of Nailbombs a while back and thankfully that worked.
My 7 string is pretty buggered, wiring-wise. Pups are Duncans but I want to change them to BKP's. The signal is being lost in the current wiring at the moment, everything looks okay as far as solder integrity goes...
So what I'm going to do is order my new BKP's and also grab myself some new pots and a new switch. I'm after 1 tone, 1 vol and 1 3-way switch, what can you guys recommend as the best bunch of gubbins to go for?
I may also need a pointer to a diagram somewhere, heh.  :lol:
Transcend
Re: New set of wiring gubbins
« Reply #1 on: February 16, 2011, 07:12:14 PM »
Firstly are you going for any fancy wiring or just straight up humbucking?
CTS or Alpha would be my recommendation pot wise and switches i have no idea i have always just used whatevers in the guitar.
Are you finally getting the painkiller?
Nadz1lla
    • Arcanum Plectra
« Reply #2 on: February 16, 2011, 07:23:34 PM »
Yeah since I learned about conversion necks for different scale lengths, I can finally see a cheaper way of getting the sounds I want, hehe. So PK and longer neck it is. Straight up Humbucking too.  ;)
Transcend
« Reply #3 on: February 16, 2011, 07:24:54 PM »
youll have no problem just using the bkp 2 hum 1 vol/3way schematic then
Nadz1lla
    • Arcanum Plectra
« Reply #4 on: February 16, 2011, 07:37:25 PM »
Don'rt know the difference between 2 conductor and 4 conductor.... or pot variations (hz etc).... oh man, lots of research to do, lol!  :lol: :lol: :lol:
Transcend
« Reply #5 on: February 16, 2011, 07:44:15 PM »
You only need 2 conductor but i would recommend 4 as then if you later decide you want extra wiring options its always there plus it helps if you ever come to sell it.
And for humbuckers you want 500k at least i think youll probably need short leg too (its a schecter isnt it?)
Nadz1lla
    • Arcanum Plectra
« Reply #6 on: February 16, 2011, 08:14:59 PM »
Nah, Jackson, it's this but with a Floyd Rose (which, again, I will be brassing up and trem-stopping with another brass L plate...nom nom nom toooone!)
So hopefully will sound like a monster when I've modded it properly. Getting into this Frankenguitar lark.  :D
Transcend
« Reply #7 on: February 16, 2011, 08:18:23 PM »
haha its addictive once you get started.
and yeah jacksons require short leg too.
Nadz1lla
    • Arcanum Plectra
« Reply #8 on: February 16, 2011, 08:49:48 PM »
Thanks dude, mucho appreciated!
Transcend
« Reply #9 on: February 16, 2011, 09:14:39 PM »
np
ToneMonkey
« Reply #10 on: February 18, 2011, 08:16:34 AM »
Pay attention to the shaft length and whether it is ribbed or smooth (I'm sure Afgan will be here to make a comment about that particular statement) when you order the pots.
Frank
« Reply #11 on: February 18, 2011, 08:59:07 AM »
If you're looking for wiring diagrams then Seymour's yer man
http://www.seymourduncan.com/support/wiring-diagrams/
and I keep linking Deaf Eddie because of his PDF about unknown colour codes on pickup wires
http://www.deaf-eddie.net/drawings/drawings.html
and this is usually right but occasionally wrong so approach with caution
http://www.guitar-repairs.co.uk/guitar_pickup_colour_codes.htm
Nadz1lla
    • Arcanum Plectra
« Reply #12 on: February 18, 2011, 05:58:04 PM »
Cool thanks for the advice, guys!
Nadz1lla
    • Arcanum Plectra
« Reply #13 on: March 02, 2011, 10:01:26 PM »
Ok, I have a pair of new BKP pots and a pair of BKP caps too...but I might be thick, as I can't find a relevant wiring diagram on the site?
It's for a set of nailbombs, 1 tone, 1 vol and a three way switch. no coil tapping or fancy stuff, just that plain ol setup.
Any ideas? I'd need a diagram that also includes the caps.  :?
Transcend
« Reply #14 on: March 02, 2011, 10:08:57 PM »
http://static.zoovy.com/img/guitarelectronics/W650-H550-Bffffff/W/wd2hh3t11_00.jpg
change the north start for the red wire
the green & whites should be taped off together
and the black and bare go to ground!
