Author Topic: String spacing  (Read 1846 times)
kake83
String spacing
« on: February 20, 2011, 11:12:01 PM »
I have installed aftermath 7 set to my guitar. I noticed that my guitar strings aren't at center of the screws that are on top of the pickup. Do they have to be? Guitar sounds great, but could it make a difference if the pu screws and strings were spaced right? Hope you understand what i mean. My english isn't perfect. :)
Re: String spacing
« Reply #1 on: February 21, 2011, 11:15:59 AM »
Is it off by alot?
As long as the string isn't completely next to the screw I wouldn't worry too much.
Antag
Re: String spacing
« Reply #2 on: February 21, 2011, 11:22:46 AM »
This isn't a problem.
As long as the string lines up with some of the screw (even if it's the very edge), then it's well within the magnetic field.
kake83
Re: String spacing
« Reply #3 on: February 21, 2011, 01:46:13 PM »
Thanks for your help guys!
I took a picture to clarify things. I think there's no problem, because every string lines up with some of the screw. But please take a look and tell me if i'm wrong.
Fourth Feline
Re: String spacing
« Reply #4 on: February 21, 2011, 02:23:51 PM »
Hiya,  :)
I just checked my B.K.Pd Les Paul and Archtops - and somewhere on each there are places where the strings are only about 1mm into the pole screw/line, due to pickup ring placement-relative to neck - or some minor issue.  This seems to be especially noticable ( as I seem to see with yours too ) at the outer two screws of the bridge pickup.
 I actually tend to (accidentally ) increase the pole/string spacing gap on my Archtops, where I prefer the whole floating bridge to nudge about 0.5-1mm towards the Bass strings, so I get a better fingering of chordal movements on the top 'E'- - and consequently a firmer note. In all cases , I have never noticed any volume / tone/ signal disadvantage - for ( As Antag said ) the strings are well within the magnetic field at it's strongest, EVEN with the relatively weaker magnetic field / pull / output of my Manhattans.  :)
« Last Edit: February 21, 2011, 02:35:56 PM by Fourth Feline »
