HSS Wiring with no Tone Pots
Started by steve@russo, February 25, 2011, 12:42:19 AM
steve@russo
I have a Blackdog and 2 slow wounds coming for my hss strat, I do not use a tone pot \, anywhere I can find a diagram for this, there are none on the BKP site
Transcend
just use a diagram that has tone pots on and dont add that part of the circuit in.
steve@russo
so the third lug that goes to the tone pot, send that directly to the ground on the input jack correct?
add4
I think you might find that on the seymour duncan website :
http://www.seymourduncan.com/support/wiring-diagrams/
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=HSS_1v_5w
HSS, 1 volume, 5way switch.
Hope that helps  (and that it is ok to post link to the seymour duncan site on this forum.. sorry if it is not, just trying to help)
Best
arnaud
Current: Emerald (n), The boss (b)
Had: Manhattan (n)
Wish list: VHII (n), Blackguard 50 (n)
Transcend
I always ground it t othe back of the pot by bending it backwards then soldering it
Quote from: add4 on February 25, 2011, 03:15:33 PM
I post links to Duncan wiring diagrams all the time, they're very good.  :)
Steve, just remember BKP's humbucker colour codes are different - green and white taped together, red to switch, black and bare to ground.
steve@russo
so on the bkp diagram there is a grey line on the bottom that goes to the 3rd volume lug and then to the tone pot, just follow as normal and ignore the tone pot?? Maybe I will put a tone pot in, is 250k gonna sound like cr@p?? Everything I see on here say 500k
Frank
I never use tone pots but I still fit them for cosmetic reasons. Just follow one of uncle Seymour's diagrams, remember the colour codes may be different for your pickups and leave out any wires that connect to the tone pots.
steve@russo
this is my plan, I will connect the 2 grounds on the 5 way together them go to ground
Frank
Quote from: steve@russo on February 26, 2011, 04:36:46 PM
Which two grounds? I can only see one ground wire on the 5-way switch.
I just common all the ground wires to the back of the volume pot. So in your diagram, wherever you see the ground symbol you can just solder that to the back of the pot.
steve@russo
I am not getting any sound ran just like this
steve@russo
now it is working but pretty niosey
steve@russo
