Author Topic: Pickup Width  (Read 5884 times)
Pickup Width
« on: February 26, 2011, 05:46:41 PM »
I know that technically you SHOULD use 53mm bridge pickups in Strat guitars and 50mm pups in Gibbos, but has anyone any experience in mixing and matching?
I've got a set of Nailbombs that I used to have in my Charvel strat, but I'd quite like them in something else, possibly an SG (Tokai anyone?)
Is there a massive difference?
Transcend
Re: Pickup Width
« Reply #1 on: February 26, 2011, 10:22:07 PM »
Ive never really noticed a difference to be honest.
The pickups always work perfectly well for me.
The best way to find out is to try it as you may notice something i havent in the past.
roland_rat
Re: Pickup Width
« Reply #2 on: February 26, 2011, 10:59:50 PM »
I have a set of F spaced VHII in a faded SG and they work fine. Im sure you must lose somthing having the wrong spaced pickup in the guitar but they still sound good to me. If you got a spare set I would certainly give them a go.
« Last Edit: February 26, 2011, 11:36:22 PM by roland_rat »
Transcend
Re: Pickup Width
« Reply #3 on: February 26, 2011, 11:02:11 PM »
Ive never noticed anything as the poles still line up with the strings they just arent perfect.
Re: Pickup Width
« Reply #4 on: February 27, 2011, 07:27:46 AM »
Awesome, that's kinda what I thought.
Thanks, guys.
Mark.
Re: Pickup Width
« Reply #5 on: February 27, 2011, 11:00:29 AM »
On most modern Gibson-style guitars, and even modern Fenders, the string spacing at the bridge is about 52mm or 52.5mm so it's in-between the two humbucker spacings anyway.
The only time you get a real spacing mismatch is putting a 50mm bridge humbucker in a guitar with a Floyd or vintage Fender bridge, because then the string spacing's 54 to 56mm and your E strings will fall outside the polepieces.
Re: Pickup Width
« Reply #6 on: February 27, 2011, 11:17:56 AM »
Thanks, PQ - good to know.
Re: Pickup Width
« Reply #7 on: February 27, 2011, 08:06:15 PM »
asian gibson copies and modern original gibsons are 52 mm
I think the only guitars I've seen with 50 mm bridge spacing were a couple Corts and PRS guitars
