Author Topic: String retainer and locking nut  (Read 3824 times)
Pale Rider
« on: February 27, 2011, 03:49:00 PM »
Is a string retainer bar really necessary with a locking nut? On a strat straight headstock?
Painkiller :: Miracle Man :: Holydiver :: Trilogies
::::::::::::::: ME(N)TAL DISTORTION ::::::::::::::
Re: String retainer and locking nut
« Reply #1 on: February 27, 2011, 04:04:34 PM »
Yes - it is there to hold the string down on both the front edge and the rear of he floyd nut so that when you lock the strings down they don't go sharp from the pressure of the clamp , which they would without a correctly adjusted bar
It is only on some lean back headstocks that the bar is not needed for this reason as the tilting back angle of the headstock is great enough to hold the strings firmly down right across the nut
On non tiltback headstock guitars it is essential to have the bar
Pale Rider
« Reply #2 on: February 27, 2011, 04:21:52 PM »
Thanks FelineGuitars! Yeah that makes sense.
So what's a good height for it?
« Last Edit: February 27, 2011, 04:27:58 PM by Nuke »
« Reply #3 on: February 27, 2011, 06:20:26 PM »
Needs to be set so the string makes good contact right across the locking nut
Take the clamps off and lower the bar till the string makes firm contact both front and back
This will mean that the clamps wont bend the strings sharp when locked down
Pale Rider
« Reply #4 on: February 27, 2011, 06:30:29 PM »
Cool, thanks for the tip!
webweave
« Reply #5 on: February 28, 2011, 10:33:00 PM »
Here's an alternative to the Floyd lock nut and string retainer. Graphtech sells a nonlocking replacement nut that is made to fit in the floyd lock nut mounting holes. You'll also need to change to locking tuners, I used Sperzel as they have staggered string thru holes which eliminated the need for the string retainer.
Although the Sperzels are heavier then the stock vintage style tuners the overall weight is about the same as the new nut is much lighter and the string retainer removed.
I believed this mod corrected a number of problems the guitar had and removed the need for the small hex wrench.
I was never a huge fan of the locking tuners but in this instance they are a great improvement. I'm sourcing parts for a new guitar with a floyd right now and I'm going to use a regular strat neck with Graphtech nut and Sperzels, that's how good it worked.
« Last Edit: March 01, 2011, 04:30:40 AM by webweave »
