Author Topic: Neck Lead  (Read 1679 times)
Moth
Neck Lead
« on: March 05, 2011, 12:23:33 AM »
I was hoping someone could suggest a real crunchy bridge (I'm leaning toward a painkiller) but more importantly a real bright whirly? glassy neck pickup to do overdrive leads on.  Sound ala Between the Buried and Me's sweep work.
THanks!
Re: Neck Lead
« Reply #1 on: March 05, 2011, 01:15:33 AM »
Nailbomb/Painkiller, neck Cold Sweat.
Frank666
Re: Neck Lead
« Reply #2 on: March 05, 2011, 01:19:36 AM »
Cold sweat neck all the way! If the bridge is mainly for riffing I'd say miracle man but if you'ree doing lead work there too, nailbomb or painkiller
asianaxeman
  • It's all about the Thrash!
Re: Neck Lead
« Reply #3 on: March 05, 2011, 11:12:20 AM »
here's some BTBAM with a cold sweat neck, bit of a shitee attempt by yours truly, I've swapped holy divers in to this guitar now
http://www.youtube.com/watch?v=5hofLDlYAIU
Moth
Re: Neck Lead
« Reply #4 on: March 05, 2011, 04:44:22 PM »
Awesome!  Thanks for the info! I'm putting them in an Ibanez S570B.  Anyone know if I'll have to change the pots, etc?
dheim
  • DON'TPANIC!
Re: Neck Lead
« Reply #5 on: March 06, 2011, 10:47:46 AM »
no need to change the pots... just a thing... cold sweat should work very, VERY well in your S, but beware of the bridge painkiller! it boosts the native high mid spike of the S and the result is truly unbearable unless you play "djent" stuff in low tunings. i'd go for a bridge nailbomb, it sounds awesome in the S.
too many? ;)
