Author Topic: Split shaft pots with tele knobs  (Read 6137 times)
tomjackson
« on: March 14, 2011, 10:42:46 AM »
My Tele has split shaft pots and I have standard Tele knobs that require solid shafts so every now and again (usually at a gig) the knob flies off.  Is there anything you can put round the shaft to make it more secure, any kind of bushes that convert the shafts?
I could change the pot but I'm to lazy for that and it's a nice pot I'd like to keep....
Re: Split shaft pots with tele knobs
« Reply #1 on: March 14, 2011, 10:54:24 AM »
You can try screwing the grub screw into the gap in the middle of the shaft?
Failing that, padding out the shaft with electrical tape may help?
Frank
« Reply #2 on: March 14, 2011, 12:42:28 PM »
Can't you just prise the two halves open a bit with a screwdriver?
I've got the opposite problem, I changed the pots to solid shaft ones and for the life of me I can't find knobs to fit the pots now.
« Reply #4 on: March 14, 2011, 04:34:45 PM »
Is there .... any kind of bushes that convert the shafts?
yes
http://www.allparts.uk.com/online-shop/guitar-bass-parts/electronics/sundries/brass-sleeves-for-split-shaft-pots-p-4026.html
Those are good.  I had some (solid-shaft) CGE pots which turned out to have slightly narrower shafts than CTS, but the brass sleeves made the knobs a perfect fit.
ToneMonkey
« Reply #5 on: March 14, 2011, 05:00:42 PM »
They look like a good idea, although I'd still end up using bluetak :D
tomjackson
« Reply #6 on: March 15, 2011, 04:28:07 PM »
Thanks.  Unfortunately allparts have none in stock and charge £3 postage so I'll try the tape method...
