Help With Installation
Started by mkh02, March 18, 2011, 06:58:00 PM
mkh02
Hey guys just received my new nailbomb pickups for my Les Paul. Only ordered them yesterday! That was quick impressed!
In regard to the soldering I have a  4 wire.
On the diagram supplied with the pickups it shows the actual main black wire coming out of the pickup itself soldered to the back of the volume pot...wouldn't this melt the plastic all around the wires? Doesn't seem right.
Should I wire the red wire to the tag on the volume pot and the black and uncovered clear wire to the back of the volume pot as an earth?
Why would the diagram show the main thick wire soldered to the pot or is it different for braided 2 wire?
Many thanks guys! So excited to get these wired in!!
QuoteIn regard to the soldering I have a  4 wire.
yes
4 covered wires (red, white, gren and black and a bare uncovered wire)
QuoteOn the diagram supplied with the pickups it shows the actual main black wire coming out of the pickup itself soldered to the back of the volume pot...wouldn't this melt the plastic all around the wires? Doesn't seem right.
No - not that wire - you are soldering the thin black wire to the back of the pot as well as the bare wire.
the green and white wires are to be soldered together and taped or heatshrunk out of harms way
this is the series connection.
Quote
Yes - spot on correct
Quote
on a braided 2 wire the outside of the main wire is the earth connection for the pickup - so that outer casing will get soldered, whilst on a 4 con wire the outer casing is a plastic/pvc sleeve and wont solder , so you use the bare wire within and one of the four covered wires as well to be connected to earth
Good luck with the soldering
Transcend
its just the thin black & the bare wire that goes to the back of the pot and yes red is your hot so it goes to your volume pot 1st tag (if i remember lp wiring correctly) for the corresponding control for pickup!
Enjoy
Transcend
hmm it didn't say a reply was posted whilst i was writing!
oh well Jonathan was correct which also confirmed my directions.
mkh02
Thanks a lot guys really appreciate your help!
