Author Topic: Intonation  (Read 7294 times)
Madsakre
Intonation
« on: March 23, 2011, 04:49:43 PM »
Hey boys, i found a screwdriver today and tried to intonate my V with the new strings on it.
It was not intonated for the tuning i used, and i could hear it horribly much when i tried to play stuff other than power chords :P
Well i started messing around and came to the conclusion that all my saddles should be rolled all the way back for better intonation. It was like 35-50 cents off on all the strings in the beginning, after i rolled them all back im like 10 cents off being intonated properly. What would be the next step to intonate the last 10 cents?
should i lower the strings? if i do that i'll start buzzing. and i dont like that at all.
I tune to b. its a standard 24 3/4 neck and i use ernie ball 12-56's.
Cattlepress
Re: Intonation
« Reply #1 on: March 23, 2011, 04:58:37 PM »
Sounds like the guitar doesn't have enough range for the tuning /gauge of strings that you are using
You might need either a wider bridge or to actually move the bridge back to get the intonation right for the strings you are using
Re: Intonation
« Reply #2 on: March 23, 2011, 05:00:12 PM »
with lower tunings and fatter strings you need to move back more.  problem is that there isnt always room!
first thing is to check if you can flip the saddle around for more adjustment
what bridge does it have?
not all tune-o-matics are created equal and you may want to swap to one with a bit more adjustment
this is an ABR-1
notice it is quite narrow with not much adjustment room and has a wire holding the saddles in place
this is a modern style TOM
more adjustment room, no wire
then you get some like this with even more adjustment room
http://www.allparts.uk.com/online-shop/guitar-bass-parts/bridges/guitar-bridges/tunematics/tunematic-bridge-sg-style-2-p-4279.html
the studs also vary - but its not usually a complicated swap from one to the other
Madsakre
Re: Intonation
« Reply #3 on: March 23, 2011, 05:02:52 PM »
Its a gibson flying v. 2009 model. I might try and reverse the bridge first.
I will report in again in 30 mins :) stay tuned, and thank you!
Cattlepress
Re: Intonation
« Reply #4 on: March 23, 2011, 05:07:35 PM »
not the whole bridge - have a look at the first bridge i posted above, notice the saddles face opposite directions.  depending which way they are facing on your bridge you can sometimes flip the saddle for a bit more room
Madsakre
Re: Intonation
« Reply #5 on: March 23, 2011, 05:10:36 PM »
lol i did not turn the stop piece :P i turned the bridge around so the springs are in the opposite direction.
it almost did the trick. im down to 5 cents. except my D(G) string which is a c--ky mofo and just wont intonate properly. Im going to order a new bridge :)
Cattlepress
Re: Intonation
« Reply #6 on: March 23, 2011, 05:22:27 PM »
good - that would end badly! - and was in no way what i was saying :P
Re: Intonation
« Reply #7 on: March 24, 2011, 11:12:34 AM »
Be sure to check your neck relief and action too.
Madsakre
Re: Intonation
« Reply #8 on: March 24, 2011, 02:20:02 PM »
Hey :)
My action is spot on. The neck looks straight :)
Cattlepress
Madsakre
Re: Intonation
« Reply #9 on: April 02, 2011, 06:50:11 PM »
well went down to my friend luthier and he took a look at the v. He intonated it as good as he could. but the low b could not be intonated 100%. its 5 cents off.
well because i love the guitar that much, im going to buy a new bridge for it. This bridge should give even more resonance etc.
http://www.fullcontacthardware.com/tom.htm
Cattlepress
Re: Intonation
« Reply #10 on: April 03, 2011, 02:21:24 PM »
Blimey, that's a hefty looking piece of kit!
Re: Intonation
« Reply #11 on: April 03, 2011, 07:47:24 PM »
I like that!
I wish they were more subtle with the huge white BABICZ branding as that bugs me.
Madsakre
Re: Intonation
« Reply #12 on: April 03, 2011, 10:21:10 PM »
I like that!
im quite good at wearing logos away :P
Cattlepress
Shag101
Re: Intonation
« Reply #13 on: April 05, 2011, 03:12:00 AM »
Hey,
Let us know how it works.  I might be interested in one.  Not sure how it will effect palm mutes....seems like it would be kinda weird.
Warpig = '88 Charvel Model 1
musicmaker29
Re: Intonation
« Reply #14 on: April 15, 2011, 05:15:51 PM »
thats one way to solve it!
if the tech did his best then the bridge is the way to go - you must REALLY like the guitar! :D
