Author Topic: My marshall is just to darn loud !  (Read 17971 times)
SDE
« Reply #30 on: January 10, 2006, 10:19:08 PM »
I use a 16ohm hotplate with a Marshall TSL602 and the sound is brilliant.  The first two or three steps of attenuation hardly affect the sound at all, after that you can use the bright and deep switches on the hotplate to correct any changes that you might hear - it also has built in noise reduction and an adjustable line out.  The only thing you may have to do is to unscrew the clamp that holds the speaker cable inside the amp, to get enough length to reach the hotplate.
« Reply #31 on: January 11, 2006, 05:47:29 PM »
Quote from: Bainzy
It'd save me having to fit a DI jack to the back panel of my plexi reissue...
Exactly! One of the main reasons for getting it. To be fair to the amp it sounds good at low volumes without it. It has two cab sims as you can see from the photo single 12" or 4x12" with two mic sims one sounds brighter than the other.
