Author Topic: My marshall is just to darn loud !  (Read 17970 times)
PUMPINGDELUXE
« on: January 07, 2006, 02:21:49 AM »
I'm tired of having to crank my amp up (marshall TSL602) just to get to the juicey rock tones. (god knows how you guys with 100 watts do it.lol)
I know there are things out there like the marshall power brake but im thinking of part exchanging the badboy for something a bit more "usable" im thinking a cordford harequin? (maybe not loud enough :( ), it needs to be loud enough to practice with a drummer but not wembley stadium loud :twisted:,
Does anybody know of any class a or a/b valve amps out there ?
Adam
Devon/England
Gibson.......Fender..............Marshall
Nailbomb...StormyMonday...halo 2 !
« Reply #1 on: January 07, 2006, 08:06:25 AM »
Lots of the guys on the forum have talked about attenuators. The THD Hotplate for example. Before you change amps, have you thought about getting one of those. There a quite a few threads about this but I am sure someone else will chip in. HJM is a bit of an authority by all accounts- he will set you right.
Searcher
« Reply #2 on: January 07, 2006, 08:47:50 AM »
Depending on how much headroom you need you can get away with only 15 watts, even when in a full band situation.
Quote from: Sifu Ben
HJM
« Reply #3 on: January 07, 2006, 09:48:06 AM »
Add to that you need to remember that the design of the amp and type of valves give the tone. A pair of EL84s will not have the same tone as 4 or even 2 EL34s. So your 15w combo will still be loud (I've measured a 7 watt amp giving 118dB through a 4x12!) but it will not respond the same as a 50 or 100w amp. Even 2w can be bloody loud!!
The difference in feel between wattages is more obvious than the loudness change. A 50w JCM800 sounds much softer in the bass than a 100w, the 1oow has more punch too.
 Remember there's only a 3dB increase in output when you double the power (1dB is about the smallest volume change you can percieve without expecting the change). So there's 3dB between a 50w amp and a 100w, a speaker change can do the same, say going from a Greenback to a vintage 30 you can match the level of a 50w with V30 speakers and a 100w with Greenbacks! So try different speakers/fewerspeakers as well as attenuators - might be enough.
« Reply #4 on: January 07, 2006, 02:21:54 PM »
Just to agree with Hayden, I have a Silver Jubilee and the power switch really doesn't change the volume much, it just softens the amp.  If you want a low power amp with the same sounds you will either need to spend a lot and get the Fargen Mini-Plex (2 EL34 but just 10 watts output [yes EL34]), or look at something like the THD univalve or Cornford.  To cut the volume you could try putting thick foam over the speaker when you play at home. Depending on the style of music you are playing, some of the sound is from the volume and speaker interaction with the guitar.
I have heard good things about the sound of the Rivera small amps (Pubster and Clubster), I have a Fender Princeton II (which is the Rivera design), and it sounds great (but still keeps up with my Silver Jubilee in volume).  At home I use some stereo 3 watt valve amps and I can't turn them up without attenuating the speakers.
Bainzy
    • http://www.shredaholic.com
« Reply #5 on: January 07, 2006, 02:28:44 PM »
Quote from: PhilKing
That's strange, I thought the Jubilee's had a pentode/triode switch? When I go to triode mode on my 100w plexi there's a very noticeable volume reduction, I'd say around 40% - a hell of a lot more than when I've pulled 2 tubes.
« Reply #6 on: January 07, 2006, 02:38:13 PM »
Quote from: Bainzy
Mine is the 50w combo, so perhaps this makes the change less obvious.  It really seems to affect the dynamics much more than the volume.  I guess flat out it might make a lot more difference, but as I really prefer the full output sound I really haven't run it flat out and compared them (plus I like my ears too!).
PUMPINGDELUXE
« Reply #7 on: January 07, 2006, 03:33:04 PM »
Cheers for the info guys..  how much does a decent attenuator cost,, is it worth it ? , can they really push the valves while keeping the volume down ? (sorry im not to clued up on amp tech stuff :cry: )
Adam
Devon/England
HJM
« Reply #8 on: January 07, 2006, 03:42:59 PM »
10w on an EL34 is pretty easy, we got 1/2 watt on 4 at Matamp......similar ideas to Mavern Peal and London Power amps power selection. Just because 4 EL34s can do 100w (or 150w+) doesn't mean you have to!
The flip side to all of this is speakers and sound preassure. Half of the tone from big Marshalls comes from a lot of air being moved and the speakers working!
« Reply #9 on: January 07, 2006, 03:57:13 PM »
i have a THD hot plate, that i'm using with a JCM800 - i have to tell you that it has improved my sound to no end, and it hardly changes the tone of the amp from its cranked state at all. of course it doesn't have the same "feel" as there is not as much air moving, but it is definately DEFINATELY an option worth considering if you are happy with the tone of your 602. also check the sound clips on the THD site of the hotplate; it has some interesting demos, which clearly show you how well the HotPlate works!
PUMPINGDELUXE
« Reply #10 on: January 07, 2006, 04:17:59 PM »
Cheers this maybe a fairly cheap solution to my problem.
I've seen the THD 16 OHM hot plate going for around 259 are there any other good attenuators I should check out ?
Adam
Devon/England
Skybone
« Reply #11 on: January 07, 2006, 05:37:56 PM »
Eh.....? ;)
Bibble.
« Reply #12 on: January 07, 2006, 10:08:14 PM »
Quote from: Skybone
Eh.....? ;)
haha - there's not much competition to the hotplate. theres the marshall powerbreak, but it sucks tone. there's the weber MASS and miniMASS. heard good things about the mass, although it doesnt have so many features as the hotplate i dont think. the miniMASS doesnt sound too good (ask _TOM_) apparently.
Anything else worth a mention guys?
django5
« Reply #13 on: January 07, 2006, 10:32:08 PM »
The Richter ones are pretty good as long as you get the pair the "motherload" and the other one.
I, am Bill S Preston, Esquire...
Bainzy
« Reply #14 on: January 07, 2006, 10:50:54 PM »
most attenuators suck tone, and you'll never get the sound of an amp on 10 at relatively quiet bedroom levels because of speaker characteristics and dynamics in your hearing, but you can get close (how close depends on what attenuation/power-scaling methodes you use).
