Author Topic: C-Bomb output-high enough?  (Read 5540 times)
paulmapp8306
Re: C-Bomb output-high enough?
« Reply #15 on: April 08, 2011, 10:52:49 AM »
You just have to decide on a PU and go for it.
Im going through the same thing as you.  i have a PRS CU22 and CE22.  the CU has dragons in and Im definately replacing them with Mules - Its for the classic Rock style.
The CE though is causing a problem.  I want hotter PUs than the Mules - its for similar styles to you plus the 80s rock and some more modern (but not metal) stuff. the CE is stock - with HFSs
I have an aversion to ceramic PUs - i have no idea why (even though the HFS bridge is ceramic).  I want to get nearer the Mules Op than the 15K though really, as I dont want a hugh just in gain between guitars, just a little BUT I want a tonal difference (less vintage, smother)  Initially I though alnico Nailbombs - then Cold Sweats.  Tim said they'd be too bright and recommended the Abraxis.  I then thought about Rebel Yells - then a mix of Ceramic Nailbomb Bridge with neck SC - but the DC rating worried me.
i STILL cant decide.  Im going for the Mules first.  Ill then know what direction to take.  if I want the same kind of tonallity with more power its the Axraxis (or even Crawlers ??)  if I want more highs its cold Sweats - more scouped its Nailbombs etc.
witeter
    • Flailhead
« Reply #16 on: April 08, 2011, 11:09:21 AM »
Hi Paul lol i know what u mean. Its my first time updating pickups and as theyre not cheap I want to get it as right as possible, but yes i could end up going round in circles. At least I have narrowed it down to Nailbombs vs Warpigs. I definetely want a ceramic bridge; if i went for the Nailbombs id be happy with a Nailbomb neck also. Though with the Warpigs I am still not 100% sure about whether the Warpig neck is what i should go for. As u say maybe i should take the plunge on one and see :-)
paulmapp8306
« Reply #17 on: April 08, 2011, 11:54:04 AM »
FWIW - I kinda did the same thing with my Strat.  Went from wanting slow hands, to irish Tours, to Sultans, to Mothers Milk.
I susspect any of them would have made a drastic improvement.  I ended up just takimng the plunge and went for Irish tours.  Havent regretted it.   I may well have felt the same whichever BK I went for mind - which is why I say just pick one and go for it.
witeter
    • Flailhead
« Reply #18 on: April 08, 2011, 12:20:22 PM »
Thanks Paul i think i will do that-as u say either way itll be an improvement on my current pickup; wish me luck :-)
HairyChris
« Reply #19 on: April 08, 2011, 06:29:12 PM »
Just an aside:
I swapped VB/HFS for a Cold Sweat set on my CuRo24 after asking Tim what the closest vibe pickups were.
Bridge - CS was cooler then the HFS, but much less woolly, gave far more clarity and was significantly more organic to  boot. Deals with all gain levels very well, nicely hi-fi with it.
Neck - Funny one, this, as I don't use neck pickups much. CS neck is very smooth and clear but to tell the truth I tend to prefer "vintage" sounding neck pus over "clean" ones! It is, however, a soloist's dream (if you play proper solos, that is)!
I've never personally got on with Nailbombs - tried in a couple of other peoples' guitars and didn't feel right - but that's just me. Other folks get on with them just fine! :-D
« Reply #20 on: April 08, 2011, 11:59:16 PM »
The Abraxas is in a way a hotrodded Mule, with more balls and mids. You can cover a lot of styles with this pu. This one will do fine in the CE.
witeter
    • Flailhead
« Reply #21 on: April 10, 2011, 10:10:34 PM »
hey chris thanks for that - yeahi know what u mean about the HFS being wolly, im sure any bknuckle pickup will improve clarity when played under heavy gain. I think i will just have to sit in a darkened room and decide; Nailbomb or Warpig..
