C-Bomb output-high enough?
Started by witeter, April 01, 2011, 03:44:51 PM
witeter
Hi guys quick question. Birthday is approaching and thanks to Tim's advice Ive been eyeing up a Nailbomb calibrated set for my PRS SE Custom 24 (mahogany body). However I had a look at the PRS SE spec and it turns out that the bridge pickup I currently have is a PRS HFS with an output of 15, while I noticed that the Nailbomb ceramic output is 15.7. My only concern, (which I dont know if its unfounded), is that I excpected the Nialbomb to have a higher output. Hence im worried whether I will notice much more tightness and power compared to my stock pickup? its my first time purchasing pickups so thats why I just want to make sure Im doing the right move. Its not that im not happy with the HFS but I want to make this guitar as good as I possibly can.
Many thanks
Chris
[url="http://www.facebook.com/flailhead"]http://www.facebook.com/flailhead[/url]
[url="http://www.facebook.com/insunaband"]http://www.facebook.com/insunaband[/url]
[url="http://www.sabreguitars.co.uk"]http://www.sabreguitars.co.uk[/url]
Sabre Custom Wraith
Ibanez RGA42
dc resistance is not output
BKP's usually feel lower output than other brands, cause they don't mud up the gain
judging by the cold sweat and the alnico nailbomb that are already lower output than the c-bomb, I doubt you'll miss anything
witeter
ah ok thanks for clearing it up, u dont know what the c-bomb output is btw?
Sabre Custom Wraith
Ibanez RGA42
only dimarzio measures their pickups output
output is not static and not pickup only related
a more resonant guitar, with pickups set close to the strings, in heavy playing hands will sound a lot higher output than the same pickup in a dead sounding guitar, set far from the strings, with a soft player
witeter
ah ok cool. and what does the resistance quantity mean? dose it reflect in any way the power of the pickup?
Sabre Custom Wraith
Ibanez RGA42
dheim
yes, it gives an idea of the "power", but it's not directly related with perceived output and has absolutely nothing to do with tightness, thickness and aggressiveness, even if a hotter pickup is usually fatter. you can't compare pickups in a very close range by their DCR, but of course a 7k pickup can't saturate more than a 15k
too many? ;)
witeter
Ok thanks for that dheim :-) just wondered, in your experience will it be an upgrade going from my PRS HFS pickups to say a set of Nailbombs? i dont hate the HFS just want to make my guitar the best it can be.
Sabre Custom Wraith
Ibanez RGA42
Quote from: witeter on April 03, 2011, 08:13:19 PM
... in your experience will it be an upgrade going from my PRS HFS pickups to say a set of Nailbombs? i dont hate the HFS just want to make my guitar the best it can be.
I felt it was a definite upgrade when I went from the HFS in my Custom to a Holydiver. I liked the fact that the HD had a little less output - even though the DC resistance was similar - and sounded less muddy in the bass and less nasal in the mids. I have not yet had the chance to play a C-Bomb but I would guess that it has about the same or slightly more output than the HFS.
I felt the even bigger upgrade was moving from the PRS Vintage Bass to a Cold Sweat neck - a lot more articulate and a lot less muddy.
As Eric said, DC resistance is only one factor that affects output. Frequency response has a lot to do with how the final output is perceived. A local dealer gave me a Cold Sweat set to try, and I the guitar I tested the bridge pickup in had a Miracle Man there. Due to its brightness the CS appeared to be at least as loud as the MM, even though the MM is supposed to be the higher output pickup. Hence I could imagine that the C-Bomb appears louder because it most likely will have more highs than the HFS. But unfortunately you will only know for sure after you tried one.
witeter
Hey Stephan thank you very much for the info.
I had actually been looking at a cold sweat neckbut was going to go for a nailbomb set on Tims recommendation. And yes the HFS neck especially has a quite closed muddy sound, same for the bridge; ive kinda got used to it as Ive had the guitar a couple of years but i do remember noticing that when I first plugged in.
And yeah its shame I cant trial pickups on my guitar for a couple of days, cos as u say i wont know 100% till I try them. By the way - what music do u play? just interested to know so as to get a better idea of how those pickups work in your setup.
Thanks
Sabre Custom Wraith
Ibanez RGA42
Quote from: witeter on April 04, 2011, 02:47:00 PM
Thanks
Hi,
I play everything from Southern Rock to Blues to Country (well - that style not with the PRS) and also 80s hard rock. I don't play any extreme metal styles. I have built and modded several amps. My current favorite is a modded Marshall 1959 SLP Reissue.
Hope that helps.
witeter
Hi Stephan thanks for that. I mostly play metal in the vein of Metallica, InFlames, Nevermore and more progressive things like Opeth. It seems its quite different from your styles, though i have heard the CS is great for metal soloing also. Thanks!
Sabre Custom Wraith
Ibanez RGA42
dheim
i've got no experience with PRS guitars and pickups, but i can say that for your style C-bombs will be spot on! ;)
too many? ;)
Alex
Like Eric said, BK can feel like they are lower in gain because they are cleaner.
On the other hand the Nailbomb still stays very clear when I turn up the gain more on my amp. There is just less "dirt" coming from the pickup.
witeter
Hey guys thanks for that-to add a spanner to the works i tried a guitar a couple of days ago with warpigs in, and liked the clarity and bottom end; do you guys have any experience of a ceramic warpig? cheers
Sabre Custom Wraith
Ibanez RGA42
Quote from: Alex on April 07, 2011, 08:08:49 PM
I think this is the most accurate description for all BKPs I played so far. What you described as "dirt" I described as "unmusical trash" - that fizzy element that so many pickups have which is not musically related to the notes you play and just makes chords less articulate. Somehow BKP manage to subdue that without taking any important frequencies away.
