How can I check my pickup is working OK?
Started by artypaul, April 03, 2011, 06:48:04 PM
artypaul
I have a Miracle Man in a mahogany Dean flying V, which I haven't used for a while. I've started using it again recently, and it seems to me like it's not giving the output I remember it having. My references are a basswood Peavey Wolfgang with a Painkiller and a Mahogany Les Paul with Dirty Fingers. Compared to these, the Miracle Man sounds like I have the volume only half way up. Before I bother Tim, is there a way to check what output the pickup is giving, and whether it matches its intended specification? It could be my lousy wiring, but I've had a look and checked that nothing obvious is shorting.
Sorry if this question has been asked before - I did a forum search, but didn't come up with any threads that covered what I'm asking. Thanks for any help you can offer.
Paul.
Alex
Maybe it's just the solder joint which isn't ok anymore.
artypaul
Ok - I'll try re-soldering it this weekend to see whether that improves the situation. Thanks for the input - I'll let you know how it goes.
Paul.
Madsakre
the miracle man is extremely height sensitive too. try and raise it a bit
Cattlepress
Transcend
Here's how to check the DC the simple way
plug a lead in and get a multimeter and measure it before the ring and after with the leads
It should be in the ballpark around 17-18k
artypaul
It's been crazy at work, so I've only just got around to playing with the Miracle Man. The first thing I did, as suggested, was play around with the pickup height. This seems to have sorted the problem out perfectly. It might be that there's an intermittent fault with my soldering, so if the output drops again then I'll re-solder it, but as it stands I'm getting a great tone from the guitar. Comparing it to a Les Paul with Dirty Fingers, the V with the MM has the same round, full tone, but is just so much more articulate.
Thanks again for the advice everyone. Much appreciated.
Paul.
