Ibanez's wiring diagram for an SZ
Started by Spitfire, April 10, 2011, 07:40:31 PM
Spitfire
I'd quite like the below wiring on my RGA... so i have 3 way, but in the middle i have the inner coils of the two humbuckers..
my guitar has 2 pots..(1 tone and 1 vol.. preferably) and a standard 3 way blade switch...
is there a way i can achieve this?? im really unsure about it.. do i need a special 3 way switch? baring in mind i cant fit a toggle switch like in the diagram.
thanks, David
Fender Telecaster
Jackson KV-4
Starfield SVA-1
You can do it with the 4 pole 5-way super switch, or if you want PRS style wiring, the megaswitch P.  BK sell the superswitch and allparts or Stewart MacDonald sell both switches.
I did the same wiring on my 7 String Dean Vendetta with a Liquifire and a Crunchlab, sounds great, but I had to give it to an experienced tech and even he was nearly driven mad. It´s supposed to be the wiring Petrucci uses and it can be found on music man guitars, but try getting any information about that. Dimarzio germany didn´t know how to do it, music man germany had no idea,...turns out music man uses a curcuit board, no wiring. Finally we ordered a very specific switch from dimarzio (don´t know exactly which it was anymore, would have to look for the packeging, though the number on it´s side says 48096). It´s not a big switch at all, should fit any guitar I guess.
Long strory short: Yes, it is possible. Yes, it´s complicated. Worth it? Hell yeah.
With my PUs it gives me the best of two worlds which is a great stratesque rock sound with that certain dirt and old schoolness in it. I love it.
That Ibanez wiring does indeed use a special 4-pole, 3-way switch.  Here's the DiMarzio wiring diagram for the same thing:
http://www.dimarzio.com//media/diagrams/D.pdf
To get it hum-cancelling in the middle position, you'd need both screw coils facing the same way (Peter Green/Gary Moore  LP style) unless one of the pickups has a "flipped magnet" (PRS style).
For a blade switch, here's the Megaswitch P-Model which Phil mentioned, it's a 5-way which duplicates the wiring of a PRS rotary switch:
http://www.stewmac.com/shop/Electronics,_pickups/Components:_Switches_and_knobs/Megaswitches/Megaswitch_P-Model.html?tab=Instructions#details
