7 string bridge Aftermath..............not loving it
Started by kmanick, April 13, 2011, 03:03:15 AM
On the treble strings raise the poles closest to the neck. This will thicken the sound off those strings.
kmanick
#16
thanks for the suggestions , I'll give them a try!
can I be the devil on your shoulder?
rsf1977
Quote from: MDV on April 16, 2011, 07:56:27 AM
I actually do this as well and it works for me too. Those pole pieces really help fine tune things. I raise the bridge side on the 2 lowest strings to tighten up the bass and attack a bit it realy cuts the flub down but if you want it to sound warmer and looser you can always raise the neck side I'm sure it'll get you closer to what you're after. And in general if the pickup is closer it's going to sound fatter and more compressed, and further away more open and wider. I felt when the aftermath was far away it just really lost all it's charm it felt really weak and empty. Just try a bunch of stuff and see where you get.
Gear: Fractal Audio AxeFx II | Ibanez RGD321 | Matrix GT 2000FX | 4x12s Mesa and Voodoo Amps
kmanick
so I just looked at the pickup can I just loosen the screws? (pole pieces are screw on mine)
and do I need to do both sides (front back /not left right)
obviously I've never done this before   :lol:
rsf1977
yes you can loosen and tighten however you want. Basically if you are looking at the pickup the screws closest to the bridge side when raised will increase high end response and general tightness. The set of screws closest to the neck when raised will fatten the tone and reduce brightness, it'll probably sound a little looser. So you can custom set each strings response. I raise about 1/2-1 turn the bridge side pole under my lowest 2 strings to tighten their bass response and add attack. Under my 2 unwound highest strings I do the opposite and raise the neck side pole pieces to fatten them up and give them a slightly warmer less trebly response. So when looking at each string there is 2 pole pieces beneath each one and those 2 effect that strings tone. So remember when raising closer to the bridge adds high end and attack, and closer to the neck adds warmth and fattness.
Also, this might be subtle so don't expect it to sound like a whole new guitar. In mine I hear the change very easily. Hope this helps.
kmanick
rsf1977
and if you raise both equally you are going to increase the output for that string so if you have uneven volume response you can correct that as well. A lot of guys will follow the arc of the neck as a starting point so each string is equally distant to the pickup then tweak from there. Someone explained that altering the bridge/neck pole balance will shift the resonant peak of the pickup so raising the bridge side shifts that peak to a higher frequency and raising the neck side shifts it to a lower frequency.
kmanick
ya I just tried this for the last hour.
still no good.
Unfortunately this thing is on it's way out.
It's just not a good match for this guitar (which blows my mind since it's all mahogany with a maple top) :?
rsf1977
yea sometimes it isn't meant to be, there are so many pickups out there. You'll find the right one.
Emperoff
If you don't like ceramics, you won't like it regardless of the guitar. I've hated every ceramic pickup that I tried for anything but metal.  :lol:
