Author Topic: Another "What should I get?" post  (Read 1514 times)
JohnnyCNote
  • Великий Пахан Московского Подземного Мир
    • The current online home of Last Rites . . .
« on: April 29, 2011, 12:10:16 AM »
I have an Ibanez S7420 7-string that and would like to upgrade the pickups. Based on all the good things I've heard about Bare Knuckle, I'm leaning heavily towards a pair of 'em. My other 2 guitars are Strats. I like the single coils for chords and use the neck pickup (an SD Hot Rails) in one for lead, and the middle and neck pickups (wired to act as a humbucker) for lead in the other one. I always use either a distortion or fuzz and a heavily overdriven amp for what I'd call a psychedelic/acid rock sound (not a retro thing - more up to date) and want something similar for my Ibanez.
Check out the attached file for pickup combinations available with the 5 position selector. What pickups would be a good choice for what I've described? I was leaning towards the Aftermath, based on what I'd read, but now I'm having second thoughts.
Any suggestions would be greatly appreciated. Thanks!
Transcend
Re: Another "What should I get?" post
« Reply #1 on: April 29, 2011, 12:14:27 AM »
The aftermath works amazingly well in this wiring setup its how i had it wired in
I'm not 100% sure on it for your described sound though unless you can provide clips.
i have a recording of the beginning of a psy trance track using the aftermath in my ibanez RGD in the players section
JohnnyCNote
« Reply #2 on: April 29, 2011, 01:19:00 AM »
Here's  a couple of samples of what I mean (please forgive the poor "quality" of the recordings). I forgot to add that I really like a pickup that does feedback well:
The Iron Tree by Last Rites (1988 version)
The Crown of Thorns by Last Rites (live version)
JohnnyCNote
« Reply #3 on: May 21, 2011, 09:44:33 PM »
As a follow-up to my earlier posts, here's an example of the sound I'd like to get: Enslaved - Havenless. Specifically, the way the guitar sounds at the very beginning. Which pickup would come closest to that?
Thanks again . . .
Transcend
« Reply #4 on: May 21, 2011, 10:46:07 PM »
Hmm i think the aftermath could do this but i wouldnt say it was ideal.
I think something a bit brighter like a cold sweat would work well for it but it may not be grindy enough.
A miracle man would fill in the grind but also add a good chunk of lows & low mids too also being a bit higher output but i doubt the output would be an issue.
i think your best bet would be to email Tim
JohnnyCNote
« Reply #5 on: May 21, 2011, 10:57:05 PM »
I'm also leaning toward the Aftermath. Several people have said this should give me the sound I want.
Thanks!
