Quote from: Nadz1lla on April 30, 2011, 12:20:47 AM
On the site, looking at the comparison charts, the Aftermaths have the same stats as the Nailbombs. Are they basically "Nailbomb plus"? I already have Nailbombs in my Warlock, and Tim recommended Aftermaths for my new Agile soooooo..... just use the Nailbombs I already have? Or get a set of Aftermaths? Totally in a pickle because I always had it in my head that I would get a Painkiller Bridge and Cold Sweat Neck for this axe, and he's thrown a chopice into the mix haha! Although he did say that a Painkiller set would also be a good choice. ARGH! I'm a Libra, you should NEVER give a Libra a choice! :x
the aftermath is quite accurate, but not the nailbombs
anyway, they are completely different sounding
the aftermath sounds somewhat similar to the painkiller, but a bit less bright and less "hairy"
the alnico nailbomb is warmer, less hot, more bass heavy and a LOT less middy (the aftermath has a ton of mids)
in fact, the aftermath seems to have similar specs to both PK and NB, but the tone is much closer to the PK
the nailbomb is considerably tight for alnico, but no near as tight and "scratchy" as the aftermath
if you want different tones, don't worry about them sounding similar
