Author Topic: Spacing question  (Read 1502 times)
Paulocaster
Spacing question
« on: May 01, 2011, 01:47:22 AM »
I'm ready to pull the trigger on a set of BKP. I used to use a lot of Dimarzios, which are spaced a bit narrower. For the bridge pickup on a Gibson Les Paul, one needed an F Spaced pickup. I am wondering is something similar would be needed in the case of BKPs going in a Les Paul. While the rule of thumb is 50mm/regular spacing for LPs, I'm hesitating given the Dimarzio problem. Those of you who have a BKP in the bridge position of your LP, did you go with 50mm or 53mm spacing and how do the poles line up with the strings?
Thanks.
kevinr
Re: Spacing question
« Reply #1 on: May 01, 2011, 02:10:30 AM »
The normal spacing for a LP is 50mm, my LP has a 53mm bridge pup and it is spaced OK.
