Author Topic: I need an aggressive Mule!  (Read 5441 times)
pedrozepelim
« on: May 04, 2011, 09:35:31 PM »
Like the subject states, need some meaner and higher output Mule sounding pickups, for a slightly bright Les Paul Custom.
What's you opinion, guys?
asianaxeman
  • It's all about the Thrash!
Re: I need an aggressive Mule!
« Reply #1 on: May 04, 2011, 09:41:00 PM »
check out emeralds and black dogs and holy divers
« Reply #2 on: May 04, 2011, 10:06:05 PM »
that's the abraxas
the diver sounds absolutely nothing like a mule
the black dog might work too
quite fat and smooth, with a darker top end
« Last Edit: May 04, 2011, 10:07:58 PM by Eric Hellstyle »
« Reply #3 on: May 04, 2011, 10:06:47 PM »
I don't find Emeralds, Black Dogs or Holy Divers to be "aggressive", just punchy.
The first thing I thought of reading the thread title was Riff Raffs.....
asianaxeman
« Reply #4 on: May 04, 2011, 10:08:19 PM »
that's the abraxas
yeah i see what you're saying, i misinterpreted as more aggressive alnico pickup if I'm honest. Never tried an abraxas.
« Reply #5 on: May 04, 2011, 10:17:48 PM »
Abraxas indeed, sort of a hotrodded Mule.
Nolly
  • Global Moderator
« Reply #6 on: May 04, 2011, 11:17:35 PM »
This screams Black Dogs
« Reply #7 on: May 04, 2011, 11:40:00 PM »
I thought the Abraxas was a smoother sort of tone than the Mule, but I only played them quickly years ago through fairly quiet amps at Music Live, so my judgement may be a bit clouded! VHII seemed to have a similar vibe but with a bit more output and bite.
ztikmaen
« Reply #8 on: May 05, 2011, 02:41:23 AM »
I also want the answer to this question, but from what I've heard the Abraxas are like hotrodded Mules.
On the same note do Mules sound muddy in the neck?
Guitars:
Warmoth Jazzmaster
Telecaster Standard
Ibanez RG370
Ibanez GSZ
Amp: Fender Hot Rod
« Reply #9 on: May 05, 2011, 05:58:40 AM »
Alnico V mules maybe? Might be a no enough of what you want, but it should get you closer as well.
Nolly
  • Global Moderator
« Reply #10 on: May 05, 2011, 09:15:44 AM »
I don't think there is one, catch-all "answer". There are several PAF-style pickups in the range, which one is correct for you depends on your guitar and what you're after.
« Reply #11 on: May 05, 2011, 09:19:42 AM »
If looking for a hike in output I would have suggested looking at the Crawler - especially if your LP is a bit bright.
« Reply #12 on: May 05, 2011, 09:24:46 AM »
yes, i tend to agree twinfan. but on the other hand, higher output is mentioned.
i'm going to suggest the vh2s.. the crawler and emeralds are good, but for me don't have that aggressive attack.
« Reply #13 on: May 05, 2011, 09:34:44 AM »
Yep, I agree gwEm - VHIIs would give that 'snap' along with higher output  :)
« Reply #14 on: May 05, 2011, 10:08:20 AM »
for aggressive Mules you want an Abraxas - they are fat, but have no shortage of grunt if you want it.
