Author Topic: Clear, transparent, subtle-ish overdrive pedal with no fizz?  (Read 15202 times)
  • Truly bad since 1972
Re: Clear, transparent, subtle-ish overdrive pedal with no fizz?
« Reply #30 on: May 21, 2011, 10:39:06 PM »
cool have had a go on the fuzz you did for horsehead havn't tried the klon yet......you done any clips, vids of valvcaster or similar
juansolo
    • Juansolo's Gnomepage
« Reply #31 on: May 22, 2011, 07:33:20 AM »
I haven't the facilities sadly :( Better to test them out in person anyhow. It surprises me sometimes what people like and don't like. It's certainly not something you can predict easily on a forum!
« Reply #32 on: May 22, 2011, 10:07:18 AM »
Cool not a problem trying out guitar stuff
andyg_prs
« Reply #33 on: May 22, 2011, 04:34:39 PM »
I guess it's very subjective in terms of the sound he might be looking for.  I recently got an MI Audio Crunch Box v3.  With single coils it does everything from extremely subtle warmth / drive to extreme marshall tones.  Not as keen on it with humbuckers though.
What guitar does he play?
Cheers,
Andy
Does such a thing exist?
A mate's after one to put in front of a clean amp, and I'm really struggling to come up with any suggestions.  He has an Xotic AC+ which is more of booster, so it doesn't do the job he thought it might.  Tubescreamers and my Klone are a bit middy, and a fuzz pedal is too fuzzy!
ZVex Box of Rock might do the trick?  Anything else?
« Reply #34 on: May 22, 2011, 04:48:22 PM »
You adjusted the trim pot inside crunch box, acts like a presence(works opposite to how expect)open up the pedal for me
andyg_prs
« Reply #35 on: May 22, 2011, 05:17:28 PM »
Not yet  - is on my list of things to do...can only do in rehearsal room - and I already drive the band mad constantly trying out new pedals and sounds etc!  :)
Where is it inside the pedal?  Is it easy to see how it is set (if I want to put it back to how it was) and how does it change things moving one direction or the other?  How far does it adjust in either direction?
Cheers,
Andy
« Reply #36 on: May 22, 2011, 05:28:28 PM »
Mine was too dark before adjusting(even with tone full up)
was a small blue screw adjuster, full clock wise was very dark, turning anti clock wise added more life and treble. I went for 12oclock on mine
andyg_prs
« Reply #37 on: May 22, 2011, 05:31:41 PM »
Cool - cheers
Elliot
« Reply #38 on: May 25, 2011, 03:36:37 PM »
Another pedal that does this is the Toadworks Leo Jr -  I use one all the time as a subtle OD for my 63 Vibroverb.
« Reply #39 on: May 28, 2011, 07:47:56 PM »
Love my lovepedal amp 50
dano
« Reply #40 on: May 29, 2011, 03:01:47 PM »
Subdecay Liquid Sunshine is a great'transparent' overdrive and can do very low gain really well.
shobet
  • Look into my eye...
    • http://www.dusksky.com
« Reply #41 on: May 29, 2011, 03:11:08 PM »
A Nick Greer gheto stomp might be worth having a look at as it's fairly low gain. Not sure if I'd describe it as transparent though.
