Author Topic: What restrictions are there with vertical cabs?  (Read 2920 times)
Transcend
« on: May 29, 2011, 09:35:16 AM »
I am thinking of getting a vertical 2x12 made and would be wanting it to be 25" long and 9.5" deep so that it matches the size of my SLO clone.
Is there a restriction in how much baffle you can add and if there is a tonal trade off because of this.
I really don't require a 4x12 but if the extra baffle is going to have a negative impact i will just go that route.
Thanks guys
jpfamps
    • http://www.jpfamps.com
Re: What restrictions are there with vertical cabs?
« Reply #1 on: May 29, 2011, 05:28:20 PM »
More baffle will make the cab nearer to an ideal infinite baffle, which will extend bass response, all things being equal.
Perhaps more pertinently a larger baffle implies a larger cab and a greater internal volume which will reduce the resonant frequency of the cab.
Transcend
« Reply #2 on: May 29, 2011, 05:32:46 PM »
Hmm i arent sure i want extended bass response.
Thanks for the input
Alex
« Reply #3 on: May 30, 2011, 11:36:07 AM »
The thickness will also have an impact. The thicker and sturdier the more metal, the lighter and more resonant the more woody/vintage. Similar to comparing an ENGL cab to a Fender Bassman cab.
