Gibson R0 VOS pickup choise
Started by Jofipe, May 30, 2011, 09:05:52 AM
Jofipe
OK guys.. my first post here :)
So I have just gotten an R0 VOS, and I really wanna put in som BKP's.
I need something a bit hotter than the BB's.
What do you recommend?
I play mostly slower heavy stuff.. rock, metal.. but also blues when i'm in that mood.
I find the Warpigs TOO hot and
I dont wanna sacrifice tone for output.
Would a Les paul benefit from a pickup with a mid boost?
I would like a sweet tight tone that goes well with my Mesa Mark series.
Jofipe
Madsakre
Cattlepress
Jofipe
Yeah Iv been thinking that aswell...  you dont think they will sound harsh in a mix?
My question is a bit...  what will give the sweeter tone in a Les Paul...  high, or mid boost?   We all know it has enough bass :)
kevinr
Crawlers sound good in LPs! so do BDs.
Jofipe
I'v actually had a Burny LP with Mules front/back and it sound AMAZING. Very open and surrounding. However they might be slightly too vintage for my sound.
Abraxas?
Arrgh, there is so many options hehe...
BTW are the Mules hotter than the stock BB's?
Alex
There are many BKP that work very well with LesPauls:
Mules, Blackdogs, VHII, Rebel Yells, Crawlers.
Maybe compare the clips and the descriptions and try to narrow down your choice a bit more.
Jofipe
I guess my needs are:
*Great for a Les Paul
*Versitile: from blues to metal... rythm to lead.
Madsakre
Cattlepress
Quote from: Jofipe on May 30, 2011, 02:09:12 PM
Abraxas - check out the videos in my sig.
Bonamassive5150
I have a VHII Set in my 93 Classic Plus- it has the same slim 60's neck
These covers a huge number of musical bases.
they are really versitile and open and, like and good hot PAF pick, reacts well to power amp drive.
I use mine with a Marshall Guv'nor mk1 to bring the mids forward for lead playing.
from Bonamassa to Rhodes' these do it!
If you want more mids- i would consider Rebel Yell,  these are more of a suped up PAF a bit more of everything that he VHII has
Mules will cover that ground. If you want that PAF-character, but a little hotter look at Abraxas. For really rockin' stuff and even metal, with an edge, listen to some clips of the Rebel Yells, a different animal then Mule/Abraxas, but great for cutting rock tones and they do well in Les Pauls.
Jofipe
#12
Thanks for all the replys :)
OK So i'v seriously spend allot of time listening to the samples on the homepage.
I must admit I find the Mules to have most clarity and to be more present than the rest when played with distortion. I usually push my amps with an OD9 or a Box Of Rock...
Am I right when I find the mules better for defined harmonic rich overdrive/dist?
heres a vid of a little koncert in greece we did... i'm on the left with the black Les Paul loaded with a Warpig.  It's too hot for my liking.
http://www.youtube.com/watch?v=-yNIXw_Rqdo&feature=player_embedded#at=71
right now I have a Black Dog in my main les paul custom '73, paired with a Mule
it's very low output compared to the other bridge BKPs (NB, CS, AM, HD) I had in this guitar, so I use it very close to the strings to capture maximum picking response
you might find it a bit weak for heavier stuff, but it becomes a monster with the booster on (I use a 1980 maxon equalizer set up for a slight upper mid boost right after my crybaby)
it's quite smooth and not a tight sounding pickup without the boost, though, but some amps will correct that
the first thing that came to mind when I first plugged it into my modded JMP was early Soundgarden
search Joe Kataldo's videos on youtube
his Black Dog/Mule set videos are very consistent to what the pickups sound, although he doesn't have them in a les paul
but I think he uses a Mesa Mark, like you
if you're confident that you want low output, it won't disappoint you
but if you want mostly openness and you have a darker sounding les paul, the riff raff is the man for the job
easily the clearest humbucker pickup I ever had
Jofipe
Hmmmmm yeah. The thing is I am using a boost pedal, so output is maybe not too important. However I'm about to get some nailbombs...  My les Paul is not very bark sounding, it's kinda woody with a good sparkle.
Will the nailbombs be a good clean/light overdrive pickup aswell?
