Author Topic: Miracle Man Neck, Ibanez 5 way switch wiring problem  (Read 6785 times)
Blackmoon181
« on: May 31, 2011, 07:39:44 PM »
Hi Guys,
I was wondering if you could help me again.
Need some advice on wiring the BKP Miracle Man neck pickup into my ibanez RG370 DXL.
I have the Nailbomb already installed in the bridge position by a guitar tech and have a stock single coil in the middle
position.
when set in the 4th position on the Ibanez 5 way switch it sounds terrible and in the 5th position i'm sure its not right either. (has too much of a single coil sound) I've constructed a wiring diagram of how the guitar is currently wired up. I should just need to change the wiring of the neck pickup.
NOTE i've changed the white wire to purple and the bare wire to orange to make it clearer.
Any advice offered would be great.
