Main Menu
Buzzing tele
Started by Ian Price, June 06, 2011, 04:58:12 PM
All,
I've got the tele wired up with BGF50s. Great pickups but there is a small problem. Basically when I am touching the strings or bridge or control plate there is a small amount of hum, when I lift my hands off there is a lot of hum - even worse if I have a bit of gain. The problem gets worse at my neighbours house for some reason.
I'm assuming I've screwed up ion the wiring somewhere so will take it apart again later just to check. I may also use some copper tape but am interested to know if copper tape does indeed help shield the cavities a little. Never used it before so answers very welcome.
Cheers!
Ian.
Transcend
it just sounds to me like you have missed a ground somewhere
Just double check everything
Oroficus
I have the reverse condition on my Tele, it buzz's all the time. When I touch the control plate or the vol n tone knobs the buzzing go's away.
I think it's got something to do with the strict quality control in place at Fender USA, if a Tele is not buzzing they won't ship it out until it do's. :lol:
Just sounds like you're describing normal single-coil hum, unless it's particularly bad compared with other guitars?
It's definitely worse than other single coil guitars Philly. Just comparing it against my old '62 custom and it is noticeably worse. I've not got round to looking at the wiring yet (4 kids syndrome) but feel that there may be something wrong with my soldering work!
Sounds like yours is behaving almost right Ian (touching strings reduces it) but if it is worse than other guitars then mebbe there is something going on with the soldering/wiring.
Have you got a four-way switch? If so is there anything funny about how you've sorted the neck pickup? Do you get any effect (more buzz or less) if you touch the neck pickup cover? This might be a long shot, though. When I got it wrong it was VERY obvious that all was not well, not just "more buzz than usual" :lol:
Oroficus - you say your buzz goes away when touching the control plate and knobs. That's made me wonder, does it go away when you touch the strings/bridge?
If not, it should do, and you've got an earthing problem. All my teles (with standard tele pups in the bridge) earth the bridge and strings through the bridge pickup's baseplate and mounting screws - unlike most guitars there's no need for a separate earth wire from bridge to ground (back of a pot) on a standard tele. However, I have had one tele bridge pup that wasn't earthing its baseplate properly - it was intermittent at first and then stayed buzzing. Rather than fiddle around with the pickup wires (it was still working fine, and I didn't want to break it) I stuck an extra earth wire to the bridge plate until I replaced it with a BKP.
Cheers Andy, it's the 4 way blade with the S1 switch that I have on the Baja. I remember it being a bit of a pig to remove the original pups and replace with the BKPs. Perhaps in my haste I did a bad solder joint (or two). When I find time I'll open it up and take a look - not likely to be any time soon though!
Oroficus
AndyR Thanks for that bit of info about buzzin Tele's, thought I had better give you a reply incase you and your traits
( REF: Autism ) get all paranoid and you assume that I am ignoring you. I only went on this thread to crack some sort of
a joke and then clear off, did not expect anyone to actually give me a reply, Thanx again.
Ian did not mean to squat in on your thread like that and I am glad to hear that you finally know what your doing with
your plank ( Tele ).
P.S.  You lot leave me and my dog d!ck fantasies be  :lol:
Quote from: Oroficus on June 23, 2011, 08:32:39 PM
:lol: no wurries on my part - it was just a "here's some info if you need it" from my point of view, I'd posted it and forgotten it.
I wouldn't have thought that Ian was too fussed neither... he might be slightly more concerned that the darker "dog d!ck" side of the telecaster has, er, raised it's head, though :lol:
Hmm... "my dog d!ck is buzzing more than it used to"  :?
tomjackson
Mine does the same so when I record I use my silent earthing system and it's completely hum free :wink:
