Author Topic: HD in Bridge and...  (Read 1620 times)
mkh02
HD in Bridge and...
« on: June 08, 2011, 04:09:36 PM »
Hey guys thanks for all the advice.
After much deliberation I am definately going for the Holy Diver in the Bridge of my PRS Custom 22 Rosewood neck.
In regard to the neck, I would like to use it for soloing work as well as the bridge therefore dont want it too dull.
Is the HD neck any good? Any thoughts in regard to a different neck pickup..one that will match the Holy Diver bridge just with less treble..ie: be able to carve its own high gain solos?
The resistence of the HD neck pickup seems a bit low...
  • Random Solution
Re: HD in Bridge and...
« Reply #1 on: June 08, 2011, 04:34:01 PM »
I wouldn't read too much into the resistance of the Holydiver. It's perfectly matched to the bridge model. The Holydiver neck is supposed to be excellent, though I haven't tried that one myself. The Cold SWeat is a popular choice for neck pickups and is excellent for soloing.
Nolly
  • Global Moderator
« Reply #2 on: June 08, 2011, 11:23:30 PM »
Listen to the clips on the site - I think you will agree that the Holy Diver neck is a fluid and clear sounding pickup that matches the bridge unit very well.
If you're really keen to mix and match, the Cold Sweat is a classic choice. I personally favour the VHII neck, which has a uniquely defined yet fluid character that sounds amazing in almost any context.
asianaxeman
  • It's all about the Thrash!
« Reply #3 on: June 10, 2011, 05:58:28 PM »
HD neck just rules...! don't be fooled by the low dc resistance, it has more output than a sd 59, sounds fatter and clearer, and is good for both modern and classic sounds.
Yellowjacket
« Reply #4 on: June 13, 2011, 04:04:16 PM »
A VHII neck with a Holy Diver bridge?  ::interesting::
kevinr
« Reply #5 on: June 14, 2011, 02:55:53 AM »
The Nailbomb neck is often overlooked, it has a great overdriven as well as clean sound and would match up well with the HD bridge!
