Quote from: Kiichi on June 08, 2011, 08:51:39 PM
Thinking about the crazy version (p90 middle, push pull potis, varitone) I described still has me riled up and exited mate
Haha it's definitely an interesting idea. I'm not really sure how it works but if I'm going for the out of phase push/pull on the neck, does that mean I won't be able to also have a push/pull to split it (given that I'm having three volumes and a master tone)?
Maybe some version of that might be done with the tone poti though...don´t know.
[/quote]
Now thats something someone else has to answer, but as far as I understand the wiring, that would be problematic or impossible (every PU is wired to one poti and that poti can do either split or phase), though I think split brings more possibilitys.
Now the next paragraph is basecally me salivating along in my dreams...so be warned!
I just got that idea from my Ibanez S. There I have a 5way for a HSH config with auto splits (neck, neck outer coil + middle, middle, middle + bridge, bridge) which I like a lot. Now if you replace the switch basecally with the three push pull potis you get many possibilitys (and many wires), if polarity is chosen correct (though some posis will hum). Split set up so that it does the outer neck (for more of a tele sound) and inner bridge coil (watch the correct screw facing and get more strat sound) and there you go.
Think combos like Neck outer coil + middle p90 + full bridge
or neck outer coil + middle p90 + bridge inner coil
or neck outer coil + bridge inner coil
and regulate the amount of each coil!
Think even medium Middle p90 for character + a lot of bridge inner for power and bit + a bit of neck to smoth things out.
Ad a varitone to that even and perhaps some way to do some phasing and you got an ass full of posibilitys!!!!
If it was me I´d might even mix up the PUs a bit (not all vintage-y) to get even stranger stuff out of there, like Aftermath bridge, MQ middle and VHII neck.
This I think says: Never give me such a guitar or I might loose it and kill us all.
