ESP Eclipse II (distressed) vs LP
Started by Bird, June 20, 2011, 03:31:36 PM
Bird
How does the ESP compare to an LP. None in stock around here, just looking for opinions. Thanks
marauder
Quote from: Bird on June 20, 2011, 03:31:36 PM
It doesn't.  Not a bad guitar, in fact they are great.  Much thinner than an LP in sound and wood.  To me the ESP Viper is closer to an LP than the Eclipse in terms of sound, even though it looks similar to an SG.
Eclipse FTs are much closer, they are approximately the same thickness.
But in the end, nothing sounds like an LP but an LP.
Alex
I concur, the ESP is a different beast, though the bigger difference is in feel. If you swap pickups, they will sound closer to each other. The ESP sounds more compact and precise and I always found the neck to be quite fast in response and attack. Not telecaster level, but definitely faster than the Gibson logs.
That said, of course those "plus points" might be distinct "negative points" for some people.
I like the look of the ESPs, and the thinner body/lighter weight would be a definite selling point for me.
But ESP will insist on making all their guitars with that "Thin U" neck shape!  :x
schantist
Quote from: Philly Q on June 20, 2011, 06:05:44 PM
Not quite true, the FT Eclipses actually have a quite Gibson-ish U neck.
Thin U :       20.2mm at 1st/22mm at 12th
Regular U :  21mm at 1st/23,5mm at 12th
marauder
This one isn't lighter, its about the same as my R8.
schantist
Quote from: marauder on June 20, 2011, 06:39:02 PM
JH-3, Hetfield sig...that's probably as Les Paul as ESP gets, spec-wise
Quote from: schantist on June 20, 2011, 06:35:39 PM
Thanks, I didn't realise that.  Still a little skinnier than I'd like, but an improvement for sure!
Bah, just when I'd learned there was a thicker neck option!  :x :lol:
Nice guitar, I like the pinstriping!
marauder
Quote
It is LP thickness though.
vinchester
My ESP Eclipse 1 CTM Full Thickness. With some BKP Rebel Yell love.
I have never played Les Paul Custom before, but personally I'm happy with my Eclipse ;)
Transcend
Quote from: vinchester on June 25, 2011, 01:49:10 PM
Those covers look absolutely awesome in that guitar. They really set it off.
I've always been a fan of burnt chrome against solid black.
i currently have my set in a trans grey flame top RG and they look good but they look a lot more subtle than when against a solid black body
Transcend
is that yours?
I always wanted a JH3 but have never come across any
marauder
Transcend
Quote from: marauder on June 25, 2011, 04:03:18 PM
It is :)
Did you get it at launch or was it a lucky ebay score?
Im incredibly envious.
Do you have any clips?
marauder
Quote from: Toe-Knee on June 25, 2011, 04:07:00 PM
Picked up on ebay about 6 years ago, bloke was in Leeds.  Lucky.
