...someone can explain this?
Started by nipper, June 20, 2011, 09:23:01 PM
nipper
I have a bass pickup with 4 conductors and would realize a complete tap1/tap2/series/parallel combination with only 2 on/on mini toggle switches and found this (see 1H60):
http://www.geocities.jp/dgb_studio/1hvari_e.htm#60
my wire combinations and colors are:
series:
green=hot
brown=ground
white and yellow=connect
parallel:
green and white=hot
brown and yellow=ground
single coil 1:
white=hot out
brown, yellow, green=ground
single coil 2:
green= hot
white, brown, white=ground
I don't understand how to correctly connect  the wires to switches watchin the wiring diagram in the link: someone can explain it?
Thank you very much
J
Jazz Rock
I can't help you understand the diagram in the link, because I hardly comprehend it myself, but you should take a look at th eSeymour Duncan website, they have loads of useful wiring diagrams. As you know what each of your wires are, it shouldn't be too difficult to corrolate what you have with the Seymour Duncan colour coding.
Follow this link and take your pick: http://www.seymourduncan.com/support/wiring-diagrams/
'17 PRS SE Custom 24 - stock
'95 Epi LP classic - MQs
Jazz Rock
I didn't realise, you have some very good one on this website as well: http://www.bareknucklepickups.co.uk/main/schematics.php
ToneMonkey
