November 20, 2026, 03:40:38 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
Negative feedback
Negative feedback
Started by sgmypod, June 26, 2011, 07:09:52 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Welterweight
Truly bad since 1972
Logged
Negative feedback
Been using my mates champ sounds a little sweeter than mine was wondering if I could change mine to more champ like by changing negative feedback part of it am guessing is part ringed in my pic
Middleweight
Logged
Re: Negative feedback
#1
June 26, 2011, 08:26:07 PM
you'll have to remove the bypass cap from the 1K resistor if you want to use NFB.
alternatively, you could add a 470ohm resistor in line with the existing 1k/0.1 combo to ground and insert the NFB there (thats the way I'd do it).
Welterweight
Logged
#2
June 26, 2011, 09:16:06 PM
ahh thought already had NFB as there connected to the grounding tag
Middleweight
Logged
#3
June 27, 2011, 05:32:52 PM
looks like you have a DI out there, right? - a schematic would be easier to read, I hate layouts.
jpfamps
Lightweight
Logged
#4
June 27, 2011, 08:53:19 PM
Can't see any evidence of negative feedback around the power stage.
As HTH says, it looks like a DI out.
Welterweight
Logged
#5
June 27, 2011, 10:34:17 PM
Here is schematic...didn't think I had this
jpfamps
Lightweight
Logged
#6
June 28, 2011, 11:14:48 AM
Yep, no negative feedback.
Welterweight
Logged
#7
June 28, 2011, 11:35:33 AM
Is it possible to do frank (been a while since touched an amp)
Middleweight
Logged
#8
June 28, 2011, 05:41:14 PM
its possible - follow the instructions in my post above.
actually, I've drawn up an alteration to your schematic.
oh, and use a 47ohm resistor, not 470ohm as I said earlier.
Welterweight
Logged
#9
June 28, 2011, 10:06:04 PM
Last Edit
: June 28, 2011, 10:21:30 PM by sgmypod
so main difference is adding 47ohm resistor(to ground inbetween bit I highlighted originaly) and the 33k feedback resistor to the 16ohm output going to headphone di
what wattage do I need on these
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
Negative feedback
User actions
Print
