Author Topic: Need help/advices for Blue Note/Nantucket/Supermassive/Pig 90  (Read 6719 times)
Sait
Dear BKP lovers,
I heard nothing but good reviews about BKP products. So I am here.
Just moved from Strat to SG with P90s, found the stocks to be muddy, boomy, woody and uncontrollable. Changed the pots and caps (550+, 0.22 Spragues) and purchased a Blue Note (which is on the way) just by reading the homepage of BKP website, aiming to have a smooth balanced open, airy, stratty tones from the neck for mostly jazz, blues classic rock tones.
My chain includes a lot of FX (mostly boutique fuzzes and boutique muff clones) and amplifier is a Hiwatt custom 20.
I am not a metal/thrash guy and never had a hot pickup before but the interesting thing is many of my dream guitarists use hot pups and neither of them play metal which confuses me a lot. Frank Zappa, Al Di Meola are just two of them.
Having the BLUE NOTE at the neck for clean and classic tones and rythm work, looking forward to make my SG more versatile by adding a hotter pup at the bridge for a more agressive characteristics humbuckerish tones, besides leaning towards to SUPERMASSIVE unable to decide.
Would it be a good match for Blue Note or an overkill or will have volume/noise issues? Nantucket would be a much more wise choice? Or "hottest is the best and get a Pig 90" ?
Any comment/experience/help would really be appreciated and wishing to be a further enlightment for those who might have similar questions
P.S.: I sent these questions to BKP (to Mr. TIM) several times during last 2 weeks but did not get any reply from him/them since. I hope will get better success here.
« Last Edit: July 18, 2011, 01:22:04 PM by Sait »
  • Brokeback is back
Re: Need help/advices for Blue Note/Nantucket/Supermassive/Pig 90
« Reply #1 on: July 18, 2011, 11:48:36 AM »
I have no experience with the pickups you mention, but I think a Supermassive might work with the Blue Note. Matt Bellamy of Muse uses a Nailbomb bridge paired with a Mississippi Queen p90 which as a set i think is comparable output-wise to the Supermassive and Blue Note.
I have no idea how the two pickups will react combined. You might end up with a not so usable middle position.
If you wanna play it safe I think the Nantucket would be a good match and if you wanna play it super safe then go for a Blue Note bridge  :wink:
Sait
« Reply #2 on: July 18, 2011, 12:10:05 PM »
Thanks for your input Mr. Air, will try to call Mr. Tim in a second  :wink:
Sait
« Reply #3 on: July 18, 2011, 01:18:48 PM »
No success. OOO
Any idea experience input welcome!
« Reply #4 on: July 18, 2011, 01:51:30 PM »
Personally I think the Nantucket is a better match for the Blue Note. Both vintage sounding, but the Nantucket being raw and gritty, like the vintage P90's in Gibsons. The in between-sound will be balanced. The Supermassive has massive mids and bass, compared to the more open, less compressed Nantucket. Could be  a tad too dark/warm in an SG, unless you like that. Just my thoughts, I don't have these pu's.
Sait
« Reply #5 on: July 19, 2011, 03:43:45 PM »
All right, spoke with TIM through the phone and the bottom line for my question is:
SUPERMASSIVE will be a big jump after the BLUE NOTE at the neck.
Since the BLUE NOTE is a vintage pup SUPERMASSSIVE is being a modern voicing not really recommended however it's up to the user's taste who would like to switch between pickups and in-between those 2 different tones.
I guess I will stay a little bit conservative and will order NANTUCKET and will have my input once the pups installed.
I hope this conversation will be a nice guide for those who will be asking the same question for themselves.
Thanks once again for all inputs/comments/ideas.
« Reply #6 on: July 19, 2011, 05:01:00 PM »
Yes, very useful.  :D
I have a lot of P-90 guitars and I'm keen to try the Nantucket bridge, but for LP Specials I wasn't sure if I should try the Nantucket set or Nantucket bridge/Blue Note neck.
« Reply #7 on: July 19, 2011, 07:08:10 PM »
Yes, it's good to share experiences with the new P90-line.
« Reply #8 on: July 19, 2011, 07:38:24 PM »
I suppose it depends on what you want, for me personally I like a lower output neck pickup for playing clean passages, then flip to a hotter bridge pickup.
Sait
« Reply #9 on: July 19, 2011, 10:05:30 PM »
That exactly was my original imagination, but not brave enough, never had hot pup beforeH
How hot your bridge compared to neck? Used to use middle position where both pups active? May I replace the hot pickup characteristics with fuzzes and big muffs (cos I have a lot), or that is a different story and the output of the pup is not replaceable with anything else? Thanks
« Reply #10 on: July 19, 2011, 10:09:21 PM »
I so need to hear more about the P90s in general.
I also like the bridge hotter than the neck, since I like my bridge for powerchords with dirt and the neck for that clean overdriven singing leads. So I got a RY bridge and Mule neck and that works well for me, though I would like even more difference at times, mostly the mule being even cleaner (time to further tool with the height again)....then again, I have been called a madmen several times before.
Sait
« Reply #11 on: July 19, 2011, 10:20:42 PM »
Ohh my God Kiichi! Your bridge is twice as hot as your neck  :o... Can you easily switch between pups without no volume shock? Do you used to use the middle position? Isn't it a huge difference in the name of the outputs? Good to know about the existency of players who use pickups with giant output differences..
« Reply #12 on: July 19, 2011, 10:51:41 PM »
Don't pay too much attention to DC resistances!
If you look at the specs for the Abraxas, Crawler or Holydiver sets, the bridge model has twice the DC resistance of the neck - but they're not mismatched at all.  :D
Sait
« Reply #13 on: July 19, 2011, 10:59:36 PM »
A lot to learn about pups.. :(
Shag101
« Reply #14 on: July 20, 2011, 01:21:37 PM »
Had a MQ neck and warpig bridge in my SG.  The middle position was superb..
P90s have a lot of bite and are able to hold their own nicely with hotter humbuckers..
Warpig = '88 Charvel Model 1
