Pickups for a Les Paul 2008 Standard
Started by Xeron Brigs, July 24, 2011, 11:50:01 PM
Xeron Brigs
Hi,
I've been wanting to try some new BKPs in my Les Paul 2008 Standard. This will be my first experience with BKPs so I'm not quite sure what would be the best pickups for my needs.
I play in a Prog Metal band in the style of bands like Dream Theater, Queensryche and Porcupine Tree. I incorporate elements of Jazz, Funk, Thrash, Death, and Blues into my music as well. I tend to play in E Standard, but will also use Drop D, D Standard and Drop C fairly often.
I normally use the Bridge Pickup primarily for my high gain rhythm playing. I lean towards faster riffs with plenty of palm muting and pinch harmonics to make certain parts stand out. Tonally, I was thinking of getting a more modern polished sound, but still heavy sound; something like a mix of the heaviness of Matt Pike combined with the precision of John Petrucci. I was thinking of getting an Aftermath for this purpose as I like boosting my mids and I want to be able to get a very tight sound.
I use the neck pickup for both my clean and lead playing. I like my cleans with a slight mid scoop, slightly compressed, and with a bell-like quality with piano-like lows; something like Mark Knopfler. I like my leads to be more smooth and fluid like, a lot like Santana but with a bit of Rocky George's lead tone from "You Can't Bring Me Down" by Suicidal Tendencies. I'm not quite sure what to get for the neck, so I'll leave that to suggestions.
As for equipment, I run into a JoeMeek Optical Compressor (also functions as a clean boost), a modded Mesa/Boogie Stiletto Ace (more low end and mids than normal, and a bright switch on Channel 1), and finally into a Lexicon MPX100 that I use for either reverb or delay.
Madsakre
Cattlepress
Xeron Brigs
Thanks for the suggestions so far!
Is there any specific reason for getting a Cold Sweat Set verses putting an Aftermath in the Bridge?
As far as I know the Aftermath is a really dry pickup which might not suit the more mellow styles you're playing, but this is only stated from what I've read as I haven't tried the pickup myself. Like the others I'll say Cold Sweat neck either paired with a Cold Sweat bridge or a Nailbomb bridge.
Xeron Brigs
I've been listening to some sample clips based on the suggestions, and I think I will go with the Cold Sweat in the Neck and a Nailbomb in the bridge.
After checking out the Nailbombs, I noticed they are available in either Alnico or Ceramic. Personally, I liked the sound of the Alnico V better from the samples I heard, but I know plenty of people recommend the Ceramics for Metal. I'm planning on ordering the Alnico, but I just want to see about getting some feedback before doing so.
Madsakre
Follow your gut. Order cold sweat neck & A5 nailbomb bridge.
Cattlepress
BigB
Quote from: Xeron Brigs on July 25, 2011, 05:52:43 PM
I guess one of the reasons ceramics get recommanded for metal is tightness, and I can tell you the ABomb bridge is definitly not lacking in this area.
I know both pickups, and even though I have not tried them as a set they should be good for what you want to achieve.
Nolly
The Nailbomb/Cold Sweat set will definitely work for what you want.
Personally I'd be inclined to go for a set of Emeralds though - they're a criminally underrated pickup in the range/ Think of them as a bright and tight hot PAF set. Their lean low end keeps things very tight under high gain, while the open voicing gives excellent clarity and works exceptionally well for lower gain and clean tones as well. The neck pickup gives more power and compression than a regular PAF, but the AIV magnet means it retains a very balanced voicing that will happily cover everything from pure vintage cleans to modern shred.
Sancho
I've been thinking of a set of Emeralds for a Les Paul Traditional myself. It's a very dark sounding guitar, and I'm looking for something to make her come alive. It's a choice between Rebel Yells and Emeralds at the moment.
Hey Nonny Nonny mylord!
kevinr
I would not use a Emerald neck in a dark guitar! I would go for a Riff Raff.
Sancho
Quote from: kevinr on July 28, 2011, 11:08:12 AM
Really? From the tonechart, it would seem the Emerald has plenty of highs, no?
Quote from: Sancho on July 28, 2011, 11:24:03 AM
If I remember correctly the tone chart refers to the bridge models.
Quote from: darkbluemurder on July 28, 2011, 01:18:02 PM
Correct.
