Author Topic: No neck cracks ever with this guitar  (Read 5714 times)
  • Truly bad since 1972
Re: No neck cracks ever with this guitar
« Reply #1 on: July 26, 2011, 10:38:07 AM »
bloomin hell that is strong
« Reply #2 on: July 26, 2011, 02:13:15 PM »
Can't see the video, but I'm assuming it's not an SG.....
« Reply #3 on: July 26, 2011, 06:02:40 PM »
Quote
Stereotype: "Mahogany" (generic term which does not mean anything) necks are not strong...
Well here you have a Perfectly quatersawn Sapelli Mahogany one piece finished neck.
i agree mahogany is a generic term, and sapele is a good alternative mahogany.  but i dont think the myth is busted in the slightest
Take a gibson neck and do the same, even a gibson style neck made from sapele and you will find why people refer to mahogany necks as weak.  you just have to remember that most of the mahogany necks people will talk about are gibson style!
also, as much as wood does vary, my experiences of sapele and honduras or south american mahoganies (admittedly less than patrick's) have always led me to think of sapele very differently to the more traditional mahogany species used in guitar manufacture.  i have found it to be stiffer for one thing ;)
in other words = un fair test
JacksonRR
« Reply #4 on: July 26, 2011, 07:38:20 PM »
I agree. He didn't jump high enough to give much extra force beyond his weight. Another thing is he only put his weight in the center of it once. The other times he had both feet much closer to the bricks. I'd like to see him continuously stacking or hanging weights from the exact center until it broke. I don't know how much that would be considering string tension is greater than most men weigh and his legs don't look like they belong to a heavy man.
He still makes some absolutely stunning high quality guitars and I'd love to have one or one like them.
String tension calculator:
http://www.mcdonaldstrings.com/stringxxiii.html
« Reply #5 on: July 26, 2011, 11:02:01 PM »
I knew it wasn't going to break, but it still made me wince to watch it!
Doesn't the fact it's quartersawn make a difference?  Presumably quartersawn timber is very stiff in the direction he's standing on it, whereas flatsawn would flex more (and be more likely to break).
Having said that, I believe mahogany necks generally are quartersawn, but most maple necks are flatsawn?
« Reply #6 on: July 27, 2011, 07:36:29 AM »
quartersawn does make a differerence,  this neck would have snapped at the headstock transition if it was flat sawn
the reason is that the mahoganies traditionally used in guitar construction are less stiff than the maple and its worth thinking about grain direction carefully.  i would still say sapele is less stiff than maple too - you could do the same test with any maple neck
quartersawn maple necks are good, a little stiffer but not a major difference. flatsawn is just more commonly used as it was easily available in the sizes leo needed and there are a lot of fender necks in the world that are somewhere in between and dont suffer for it.
patrick does have a nice stock of perfectly quartersawn sapele which he uses regularly for bodies and necks. iirc he was showing off the stack a few months ago at PG
JDC
« Reply #7 on: July 27, 2011, 12:52:15 PM »
My backwards rationalisation of how to make a good guitar is totally confused.
Any idea how sapele compares to mahogany tonally?
« Reply #8 on: July 27, 2011, 01:39:45 PM »
i dare you to email him and ask him ;)
i know what the huff would say from his posts on the subject over at PG - he would tell you its a silly question because:
1) all wood varies from piece to piece
2) mahogany is a generic term that means little more than brown wood
3) 'mahogany' can be bright and snappy as well as dark and warm - so your usual assumptions about mahogany tone do not apply
i largely agree with the first 2 points, they are the same for any wood generalisations - but i still distinguish between mahogany and sapele because i find it a useful distinction.
guitars were traditionally built with south american mahoganies, this is woods from the Swietenia genus of the Meliaceae (mahogany) family.  of course they vary between pieces, but these are the mahoganies people tend to refer to as warm sounding and tehse are the ones that created the classic tones we lust after..  they are also almost all CITIES protected.  IF you want a traditional gibson tone the easiest way to get it is with these woods. ... but, mahogany used by modern factories is not the same, can come from all over the world and can vary a hell of a lot - so it is more of a generic term
Sapele is still part the Meliaceae family so is a type of mahogany, and will have some crossover with those other mahoganies we are used to.  But in general terms its stiffer and has a more interlocked grain.  this can make is slightly harder to work than the Swietenia's as tear out is more of a potential problem. tonally i would argue that its a little brighter than most would expect of a mahogany due to its extra stiffness.  it does look different too.
So i know patrick doesnt like tonal generalisations about wood at all, but i still think they are a useful starting point for a builder.  if a customer asked me for a mahogany like tone with a bit more bite i may start considering sapele over honduras, but it still comes down to individual pieces of wood.
« Last Edit: July 27, 2011, 01:42:41 PM by WezV »
« Reply #9 on: July 27, 2011, 04:24:07 PM »
decided to give it a go - with a really cheap squier neck ;)
http://www.youtube.com/watch?v=k7t2TsEI6dE
« Reply #10 on: July 27, 2011, 08:47:56 PM »
Please don't use that technique for relicing my Strat neck!  :o  :P
« Reply #11 on: July 27, 2011, 08:55:31 PM »
too late :P
« Reply #12 on: July 27, 2011, 10:22:42 PM »
AAAAARRRRGGGGHHHHHH!!!  :x
« Reply #13 on: July 27, 2011, 10:35:48 PM »
he he, you know i am not starting on the actual relicing till the lacquer has had more time to cure ;)
and no, i would never stand on a guitar neck i intended to use for anything.
« Reply #14 on: July 27, 2011, 11:11:02 PM »
I knew you were kidding, of course..... but it was such a horrible thought!  :wink:
